Originally posted by joip
This same thing happened to me at about the same 180 mark. Were you using the lens manual or automatic? If I remember correctly, every instance I've read of the 150-450 sticking has been around 180. Would that 180 mark play in somehow as to how & where the force being created locks at that spot. Not an engineer just trying to think like one! My 150-450 was sent back from the factory & it works perfectly fine. I will remember not to press it in the future. Wish they would come up with a fix that prevent us from having to worry about it.
I don't know, but I noticed something surprising on my copy of DFA150-450. When the zoom is fully retracted, there is still about 5mm space between the body and the moveable part of the lens (it is not the 180mm position), which seems not to be a space by original design. If you think about it , Ricoh may have added a limit to prevent the zom to retract fully and the sealing to drop.... if that's the case, that would explain why my 150450 never failed , and also, it could be that the failure happen to first production batches sold. And issue corrected by mechanical limit on the next batches.
