10-10-2016, 02:43 PM   #1
Pentax K30 after a fall !!
Hello dear forum.
My camera fell of my hands and now it has the following problem:
I need to keep the exposure -2 in order to take an almost normal photo. Otherwise the photo is overexposed, but...
if I turn on my flash (on camera flash) then everything goes back to normal (I must put the ev to 0 otherwise my photo is underexposed).
Does anyone has any clue on what that might be and what to do in that case?
Should I try and open my camera?
Thank you all in advance
10-10-2016, 03:09 PM   #2
jlstrawman's Avatar
QuoteOriginally posted by Christos29 Quote
Sorry to hear this, Christos29. If you don't know what your doing, you might end up with a bigger problem.
I guess you could gently shake the camera to see if there area any loose pieces. If it was mine, I would
take the battery out and let it sit for a few hours. Removing power MAY reset the electronics. If that doesn't help,
it would be best to contact your closest authorized repair facility. Good luck.
https://www.pentaxforums.com/forums/189-repairs-warranty-service/316284-penta...e-listing.html
10-10-2016, 03:29 PM   #3
UncleVanya's Avatar
Given that it is a K30 I would wonder if the aperture actuation is not working right. Since P-TTL flash can adjust light based on what it gets back from the preflash it can adjust to the aperture not working as expected.
Face the camera towards youself - set it to f/22 or something nutty small. Fire the shutter while looking in the lens with enough light to see the aperture. Does it close down to a tiny hole or does it look bigger than expected. Now try f/4, then f/8 - compare it to a similar manual aperture lens of the same focal length if possible.
Also do you have multiple lenses you can try?
10-11-2016, 12:04 PM   #4
Thank you all very much for your replies. I left the camera without battery for 8 hours and the problem still exists. Also I tried multiple lenses and I saw the aperture and it seemed to be ok. Small enough and big enough when it should...
The problem disappears when I shoot through live view or when I use the flash. So I guess there is some problem with the light sensor?
The next thing to do is to go to some service center.
Thank you very much again for your replies.
Ciao!!!
10-12-2016, 02:50 AM   #5
Sounds actually more like a slow shutter problem. Flash exposure is more or less unaffected by shutter speed.
camera, fall, flash, k30, pentax k30, pentax service, photo, problem, repair, service, warranty
Do I buy K70 after K30 fail? jules99 Pentax K-70 39 09-19-2016 07:18 PM
autofocus problem with DA*300 after firmware 1.06 update for K30 channeler Troubleshooting and Beginner Help 8 09-06-2015 09:39 AM
K30 looses picture after switch off smurf Troubleshooting and Beginner Help 4 05-05-2013 09:17 PM
Black & White Bird sanctuary after the leaves fall jmschrei Post Your Photos! 2 10-21-2010 04:25 AM
Hotshoe replacement after fall Mister Guy Pentax Camera and Field Accessories 2 05-29-2010 09:30 PM
All times are GMT -7. The time now is 12:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
