10-18-2016, 11:49 AM   #1
kjphilippona's Avatar
Can not fine focus adjust Tamron 70-200 on my K-3
I have tried to fine adjust the focus on my K-3 with the Tamron 70-200 mounted. Even at the max -10 the lens still shows back focus on my Datacolor SpyderLensCal Autofocus Calibration Aid. Is there any thing i can do
10-18-2016, 12:02 PM   #2
BigMackCam's Avatar
I had two copies of this lens in a row with front-focusing that couldn't be adjusted out using AF fine adjustment. My Tamron 28-75 f/2.8 was the same. Sadly, I gave up on the 70-200 and bought the DA*60-250 instead. However, I sent my 28-75 in to Tamron's UK distributor and service center, and they returned it after about a week, properly calibrated (it works perfectly now with -4 AF fine adjustment). I'd suggest you send yours in too... I'm sure they'll be able to sort it out.
10-18-2016, 12:11 PM   #3
if the lens is back focusing you need positive adjustment, not negative
10-18-2016, 12:47 PM   #4
QuoteOriginally posted by wibbly Quote
Sorry for wrong wording At -10 on the camera, the fine focus is around 2 closest to the camera.
10-18-2016, 02:05 PM - 1 Like   #5
It needs calibrating. If it's in warranty, send it to them and it should be mostly free (apart from postage). Their warranty is location dependent, I'm not sure how long it is on the other side of heaven, but here it is 5 years as long as you register it at purchase.
10-18-2016, 02:15 PM - 1 Like   #6
BigMackCam's Avatar
QuoteOriginally posted by victormeldrew Quote
Plus - here in the UK, at least - even if your lens is outside of warranty or (shock horror ) "grey market", they will still accept it as a chargeable service job. Not cheap, but not that expensive either... I think about 80 - 90 inc VAT, and the lens comes back calibrated, tested and clean.
10-18-2016, 02:22 PM   #7
Yes, I took the grey market risk myself and can get it done three times for the money I saved on my two lenses. Not that I needed it, thankfully.
Save
10-18-2016, 02:26 PM   #8
GolNat's Avatar
I am having a similar issue with my Tamron 17-50. At 2.8 it didn't look very sharp. I set the in camera adjustment to -10 and it is a lot better but I feel like maybe it could be even more so if I send it in for calibration. Mine is grey market as I bough it used from Japan but for what I paid I wouldn't mind spending a little to make it better. I was going to try calling the US repair department to see if they can give me an estimate on cost.
10-18-2016, 02:33 PM   #9
BigMackCam's Avatar
QuoteOriginally posted by GolNat Quote
Are you using a tripod and a reliable test subject? Also, have you tried the full range of calibration settings one by one, from +10 through 0 to -10, and confirmed that it is more in focus at -10 than any of the other settings? If you've done that, and you're absolutely sure it's a case of having reached the limit of adjustment, then calibration would almost certainly help.
10-18-2016, 02:56 PM   #10
GolNat's Avatar
I did not do all of that. I did use a tripod, 2 sec delay, camera at 45 degree angle, aiming at a green sticker on a book. The green sticker was out of focus at 50mm and f2.8. When I changed the number by only 2 I didn't notice anything so I started doing bigger steps. Went the wrong way at first so I went the other way and only did -5, then went -10 and said "hey that looks better".
So are you saying that -8 or -9 could be better then the -10? I figured it was a linear scale and was measuring distance.
10-18-2016, 03:23 PM   #11
I purchased the lens from a member on the Marketplace, not sue how old it is
10-18-2016, 03:28 PM - 1 Like   #12
BigMackCam's Avatar
QuoteOriginally posted by kjphilippona Quote
It's highly likely they didn't know that the lens might need calibration. It seems a number of people assume that the lens just isn't that sharp at f/2.8 and/or at close distances, so they stop down to f/4 or f/5.6 at which point the depth of field is probably enough to give decent results. It's also more than possible that on their camera body, it was within the +/-10 limits for AF fine adjustment.
The good news is that this isn't an uncommon situation, and you can get it calibrated by Tamron's service facility. It will cost, yes, but only a fraction of what the lens is worth - and it makes sense to get such a nice lens performing as it should. While the lens is at the service facility, they'll check it over generally, so you'll have peace of mind that everything else works properly too
10-18-2016, 03:56 PM - 1 Like   #13
BigMackCam's Avatar
It is a linear scale, yes. Can I recommend that you read and follow the process outlined here:
Fixing Front and Back Focus - The Remedy - In-Depth Articles
Hope this helps
10-18-2016, 04:55 PM   #14
Thanks Mike, this was very helpful. my only question is, does it matter if the test is done indoors or out ?
10-18-2016, 05:09 PM   #15
BigMackCam's Avatar
You're welcome Indoor or outdoor is fine, but you want a good amount of light... e.g. natural light from big windows on a bright day, or strong incandescent (not fluorescent) overhead lighting like you'd have in the kitchen.
focus, focus adjust tamron, k-3, pentax service, repair, service, tamron, warranty
Did you have to fine adjust the focus on your K-1? Lampo Pentax K-1 39 12-13-2016 11:46 AM
Fine Dust in D-FA* 70-200 2.8 Zoom/Focus Rings Joshua A Pentax SLR Lens Discussion 14 06-12-2016 03:06 PM
Manual lens works fine on K200d but not on K-3 simon_199 Troubleshooting and Beginner Help 17 03-29-2015 08:39 PM
Tamron 70-200 auto focus faster with k-3 or k-5 IIs ? skid2964 Pentax DSLR Discussion 11 01-25-2014 12:27 AM
K-01 with Tamron 70-200 will not nail focus treebeard Pentax K-01 8 03-22-2013 05:46 AM
All times are GMT -7. The time now is 01:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
