Good Day Everyone
I have a Pentax Lens 14mm 2.8F
The lens was purchased used and I have little to no experience with cameras. Ive seen a hood on Ebay (link below) that screw in. (looks like they do anyways)
Mennon 77mm Wide Lens Hood Petal Shape for Pentax smc DA 14mm F2.8 ED (IF)
I can rotate the ring and it feels like it can lock into its original position but won't stay there completely as if a glue or link was broken. Would the screwing in of the hood create sufficient pressure to lock the ring in. Should I just Glue it back in?
Thanks for any help.
