Originally posted by jhaji Is the "dark frame" problem more severe at larger apertures than smaller ones? My K-30 gives much better results on Av mode @ f/8 (than wide open) & progressively gets even better as the aperture is made even smaller.
The basic problem is that the aperture is closed down to the lens's smallest opening regardless of what the body called for.
Assume the lens's smallest opening is f/22.
If the body calls for f/4, it will get f/22.
If the body calls for f/8, it will get f/22.
If the body calls for f/16, it will get f/22.
Thus you get better results "at larger apertures" because the value called for is more distant from what it actually gets
Originally posted by jhaji Like everyone else's, mine works fine on M with stop down metering which is also perplexing since the solenoid would be responsible for closing down the aperture.
The solenoid controls limiting the amount of closedown, not causing the closedown, so it has nothing to do during 'green button' metering..
