11-27-2016, 10:56 AM   #1
klh's Avatar
Replacement wide angle diffuser panel for AF540 FGZ II?
Does anyone know where you can buy a replacement diffuser (wide angle panel) for the Pentax AF540FGZ-II for a reasonable price? I pulled it out one time and the little hinge points broke right off.
11-27-2016, 12:04 PM   #2
swanlefitte's Avatar
Mine broke on my 360. I didn't replace it but to get the zoom to work i stuck a piece of wood in its spot.
11-27-2016, 12:22 PM   #3
UncleVanya's Avatar
What about using a pop on diffuser?
Universal Foldable Soft Box Flash Diffuser Dome For Canon Nikon Sony Pentax | eBay
11-28-2016, 07:05 AM   #4
klh
klh's Avatar
QuoteOriginally posted by swanlefitte Quote
Thanks swanlefitte. I may have to try that.
---------- Post added 11-28-16 at 09:06 AM ----------
Thanks UncleFanya, that would work for some shots, but the flash will always assume it is wide angle with the plastic diffuser panel broken so I can not set the focal length, even in manual mode. I typically use bounce flash, and a wide angle bounce is not always ideal.
11-28-2016, 07:45 AM   #5
UncleVanya's Avatar
QuoteOriginally posted by klh Quote
Thanks UncleFanya, that would work for some shots, but the flash will always assume it is wide angle with the plastic diffuser panel broken so I can not set the focal length, even in manual mode. I typically use bounce flash, and a wide angle bounce is not always idea.
I didn't realize that - hopefully the trick with a wood block works for you.
12-05-2016, 02:47 PM - 1 Like   #6
Can you drill a small hole and use epoxy glue to attach a piece of wire?
See this thread.
I'm sorry I lost all the intermediate photos. The one at a end of the thread shows the panel after being repaired.
12-06-2016, 12:07 PM   #7
klh
klh's Avatar
QuoteOriginally posted by SOldBear Quote
See this thread.
Thanks. I saw your thread, and I may have to try something like that. The hinge tips on both sides broke off (but I do have them), so I am tempted to try gluing it back together first. The tips are much smaller on the model II. I am amazed at how flashes (not just Pentax) have such a cheap part that is so difficult to replace. It's really a poor design.
12-22-2016, 05:50 AM   #8
klh
klh's Avatar
Here's an update in case anyone else runs into the problem. Using the broken panel, I was able to push the sliding bracket down into the flash until it seated with a click. Of course, the panel won't stay in, but now the flash thinks it is so the zoom features work as they are supposed to. Since I don't really need the panel, it's not necessary to replace it. For the rare times I need a wide angle I can always use one of my Sigma or Yongnuo flashes.
12-22-2016, 11:41 AM   #9
Interesting as i recall on the 360 1, it was a button inside in the middle. My piece of wood holds it down while still letting the bounce card slide out.
af540 fgz, diffuser, flash, panel, panel for af540, pentax service, repair, replacement, service, warranty
AF540 FGZ ii - battery connection tomO2013 Repairs and Warranty Service 5 07-15-2016 04:39 PM
Pentax AF540 II Melting the Diffuser K David Flashes, Lighting, and Studio 11 12-08-2015 05:08 PM
42" diffuser panel and natural light panoguy Flashes, Lighting, and Studio 3 04-18-2014 06:26 AM
Best diffuser for my AF540 aegisphan Flashes, Lighting, and Studio 31 04-21-2008 07:19 PM
All times are GMT -7. The time now is 01:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
