12-23-2016, 08:46 PM   #1
FA 28-70 f/4 Minimum FL 31mm--A "Simple" Adjustment?
-- My FA 28-70 f/4 lens will not open more than 31 mm (it used to). Camera says 31mm, and comparing to another FA 28-70 f/4 on same camera, it is a bit narrower FOV.
-- Anyone have any suggestions/a mnor adjustment to fix it?
-- It is a fine lens but the cost of a used one is low enough that sending it out for repair may not make much sense.
12-23-2016, 10:28 PM   #2
dms
Many thanks dcshooter.
12-24-2016, 10:21 PM   #3
dms
Yes AF works fine. Except that it does not zoom open more than 31mm FL, all seems normal.
It started out by not zooming out all the way unless I applied more torque than normal, and now/finally only operates in the 31~70mm range--as indicated by the camera.
camera, f/4, f/4 minimum fl, fa, fa 28-70 f/4, fl 31mm--a, lens, pentax service, repair, service, warranty
For Sale - Sold: Pentax the "reds" F 50 1.7, F 70-210, F 28-80, F 35-105 xinanbei Sold Items 12 08-16-2015 08:07 PM
"Longer" alternative to FA 28-70 f/4 AL zoom? cyberjunkie Pentax SLR Lens Discussion 11 05-27-2014 05:35 AM
"Manual" AF fine adjustment of FA 50 1.4 on the 1.4 end Iksobarg Troubleshooting and Beginner Help 9 08-26-2013 12:34 AM
another "should I buy?" thread: DA 70mm f/2.4L - I have a Tammy 28-75/2.8 & FA 50/1.4 m8o Pentax SLR Lens Discussion 11 08-26-2008 09:09 AM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
