Show Printable Version 6 Likes Search this Thread
01-30-2017, 09:20 AM   #1
HELP!!! 80-200mm Unfixable!?!?,
I recently received word from Precision Camera Repair that my FA* 80-200 f2.8 cannot be repaired! It seems that the lens made it all the way to Japan for repair and they said "lens is no longer serviceable." It doesn't auto focus properly. Any ideas on what I should do? It seems as though I am finished and that I have a giant paper weight!
01-30-2017, 09:27 AM   #2
Digitiser of Film
BigMackCam's Avatar
I think you need a little more info from Precision... Is the return of your lens unrepaired because the facility in Japan no longer services this model (it is, after all, quite a few years out of production), or because the specific issue with it is considered unrepairable? If it's the former, I'm sure there are other service facilities who could sort it out for you. If the latter, it would be good if they could tell you why it's unrepairable, as you may still find someone who can carry out a repair of sorts...
01-30-2017, 09:31 AM   #3
jatrax's Avatar
See if you can get a more precise answer as to why it cannot be repaired. Possibly parts are no longer available from stock. Which is not always the end because while a factory technician without parts cannot help, sometimes a private repair shop can do non-standard repairs or even fashion a needed part.
Find out what is wrong if possible, then send it to a private shop like Eric or maybe @dcshooter can help.
01-30-2017, 09:31 AM - 1 Like   #4
UncleVanya's Avatar
It really matters what is damaged. Even damaged circuit boards may be salvaged. Damaged elements are a huge issue as well as some structural parts. Enterprising folks can possible fabricate or repair many parts.
01-30-2017, 09:33 AM   #5
It seems that the facility in Japan no longer services this model. Or, at least that is most consistent with what I was told. But did they really need to send it to Japan to get that answer? They couldn't have received that answer over the phone?
Also, do any of you know of any other Pentax repair specialists?
01-30-2017, 09:35 AM   #6
QuoteOriginally posted by mattieyp3 Quote
Sound fishy to me, Send it to Eric.
01-30-2017, 09:40 AM   #7
QuoteOriginally posted by niceshot Quote
Who is Eric?
01-30-2017, 09:42 AM   #8
boriscleto's Avatar
Who is Eric?
Home-Pentax Camera Service
He might not be able to help as it is an auto-focus lens...
KEH might be able to do something...
01-30-2017, 09:53 AM - 1 Like   #9
amateur dirt farmer
pepperberry farm's Avatar
you may also want to contact Advance Camera Repair, in Portland:
01-30-2017, 11:24 AM   #10
Who is Eric?
Home-Pentaxs
01-30-2017, 02:08 PM - 2 Likes   #11
If you do end up with a 'giant paperweight', I'd be quite happy to feature it off your hands. I've got some 'papers' that might need holding down, and I'd even happily pay shipping! I can't promise that I won't go out and treat it as a manual focus fast zoom though... 😉
01-30-2017, 05:11 PM   #12
mee
That's an older lens, discontinued 13 years ago. They likely don't have parts and probably haven't in many years.
01-30-2017, 05:16 PM   #13
here is your fix C Normal SMC PENTAX FA 80 200mm f 2 8 ED IF AF Lens | eBay
01-31-2017, 04:54 PM   #14
UncleVanya's Avatar
Not found. Even when adding sold items to the search. What was it?
01-31-2017, 04:56 PM   #15
mee
There was a copy from Japan.. had a beatup exterior but the glass (in the photos) looked clean. Wanted 400 dollars.
80-200, fa*, pentax service, repair, service, warranty
Help! I need help in the Phoenix, AZ area! AggieDad Troubleshooting and Beginner Help 6 11-06-2016 08:12 AM
TWO K-50s giving me the same error !!! Pentax is no help. HELP!! RedSky Troubleshooting and Beginner Help 12 06-09-2016 03:12 PM
Help, help, help! I need a case, box, trunk... dansamy Pentax Camera and Field Accessories 13 02-18-2014 06:17 PM
HELP! HELP! K5 not working/back from CRIS psychdoc Pentax K-5 & K-5 II 118 10-19-2011 05:50 AM
Little help? help me identify possible problem and lens mount. mediaslinky Pentax SLR Lens Discussion 4 08-23-2008 06:32 AM
All times are GMT -7. The time now is 09:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
