Originally posted by dcshooter Is the second photo showing the screw anchor having broken off? If not, it's just a matter of removing the name ring and trightnening the screws (trivial time/cost). If it is broken, you'd have to build a new anchor somehow or replace with an inner barrel from another lens. If you have the bit that broke off, you might be able to reattach it with solder.
I am not sure what had happened. The lens had this issue when it was bought and the seller resolved it by tightening the screws. I am assuming that it's only the screws being loose again as I don't remember anything falling away.
Sincerely
通过我的 Nexus 6P 上的 Tapatalk发言
