02-28-2017, 12:42 PM   #1
Pentax ME Super Shutter speed fault
Hi guys,
I bought a Pentax ME Super about 2 weeks ago, and yesterday sent in the first roll of film to be developed and all the pictures came out dark, in fact they said that the film looked like it had not been exposed at all.
When I got home I found that the light meter is working and is showing the correct shutter speed for the lighting situation, but the shutter speed seems to be at the maximum, so to me that says that what ever is controlling the shutter speed is not working correctly and the shutter speed to way too fast, thus causing the pictures to not be exposed.
Has anyone else had this problem and can it be fixed?
This is my first film camera and I really want to get into shooting film.
Thanks for your advice in advance.
02-28-2017, 07:59 PM   #2
Probably the shutter magnet isn't isn't holding the second curtain so the shutter doesn't open. Sometimes it is caused by the shutter not getting cocked and sometimes the the magnet is dirty or has failed. Cleaning the shutter may fix it. Tuner cleaner might work. Don't get it anywhere but the shutter.
02-28-2017, 08:17 PM   #3
Not a Number's Avatar
Are you sure the film engaged on the take spool at all? Was there some resistance on the rewind handle for more than just a few turns? And you can usually hear and feel when the tail of the film disengages from the take up spool, goes past the pressure plate and ends up in the cassette. You should also see the cassette spool knob rotate when you advance the film. If the film wasn't engaged on the take up the knob won't turn.
film, pentax, pentax service, pictures, repair, service, shutter, warranty
ME Super Shutter Speed Issues camrnw Film SLRs and Compact Film Cameras 11 11-01-2021 03:28 PM
ME Super, unreliable shutter speed Don Promillo Film SLRs and Compact Film Cameras 5 04-10-2016 11:17 AM
Fault with ME Super, winder and shutter jam. lab rat Film SLRs and Compact Film Cameras 10 01-28-2013 11:11 AM
ME Super Shutter speed problem clawhammer Film SLRs and Compact Film Cameras 5 11-10-2008 12:44 PM
ME Super Stepless Shutter Speed? KungPOW Film SLRs and Compact Film Cameras 4 05-06-2008 08:45 PM
All times are GMT -7. The time now is 07:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
