Originally posted by Jeff Lopez eyes are tricky nowdays jaja..
Tell me about it
Originally posted by Jeff Lopez do you think if I use a HDMI monitor it will help af fine tune? I know for sure the dioper is tack on spot
There are a few ways to go about it. In this instance I'd probably do the following:
1. set the camera on a tripod to ensure it stays in the same position
2. switch to live view and accurately focus on the subject, using magnification to ensure you get it spot on (after this point, don't touch the focus ring)
3. switch back to regular operation
4. set AF fine adjustment to "ALL" (as you can't set individual parameters for an old manual lens)
5. set the level of AF fine adjustment to -10
6. check to see if you get focus confirmation when you half-depress the shutter button (no need to take a photo), and note down whether you do or don't
7. repeat steps 5 and 6, changing the amount of adjustment each time (-9, -8 and so on, all the way to +10) - i.e. go through all of the possible settings
You'll probably find there are three or four settings where you'll get confirmation. Pick one in the middle as your final setting. So, if you find you get focus confirmation with +4, +5 and +6 AF fine adjustment, use the setting +5 in future.
Does that make sense?
