Show Printable Version 11 Likes Search this Thread
06-22-2017, 11:17 AM   #16
I have replaced the flash shoe foot of my AF360FGZ, but I lost the flash shoe lock pin spring. I have attached a picture of the inside of the hot shoe with my tweezers pointing out the pin. The metal piece that goes over it is to the side of the shoe on the table. I am assuming that the spring was supposed to fit over the base of the pin and the metal piece that I show to the right goes over it. I have put everything back together without the use of the spring and everything is working fine. The flash seems very secure when attached to my K-3II and the shoe lock lever is locked down. I am very happy that I have the flash shoe replaced and that all flash performance functions are working fine.
PENTAX K-3 II  Photo
06-23-2017, 10:34 PM - 1 Like   #17
QuoteOriginally posted by C_Jones Quote
In your photo, the next step would be to put the spring on the pin then put the bracket on, retaining the spring.
The function of the spring is to push a locking pin out when the locking lever is locked. Unlocking the lever forces the pin up against the spring.
You could use a spring out of a biro cut to length.
PENTAX Q  Photo
06-24-2017, 08:01 PM   #18
QuoteOriginally posted by alfa75ts Quote
Thank you.
af360fgz, af360fgz hot shoe, bottom, breaks, camera, cost, flash, instructions, link, pentax service, plastic, post, repair, service, shoe, split, warranty
Pentax AF360FGZ II broken hot shoe. Advice for buying replacement parts. Huy Repairs and Warranty Service 7 08-11-2016 10:32 PM
Pentax hot shoe adapter + off shoe adapter - any limits on the flashes used? MSL Flashes, Lighting, and Studio 4 10-25-2014 06:13 AM
AF360FGZ hot shoe broken godavari Flashes, Lighting, and Studio 4 01-07-2013 09:02 PM
Wein Safe-Sync Hot Shoe to Hot Shoe Iowa Tom Pentax DSLR Discussion 1 09-12-2009 09:20 PM
All times are GMT -7. The time now is 03:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
