07-12-2017, 09:09 AM   #1
W90 immersed in salt water no longer working
I would like to find a schematic for W90 so I can attempted to repair/clean it as the camera value is probably less that repair cost. Any help would be appreciated!
07-12-2017, 10:57 AM   #2
jlstrawman's Avatar
QuoteOriginally posted by tyrone Quote
Sorry, but, in most cases, electronics meeting salt water, is the kiss of death. Further, as far as I know schematics / service manuals are typically unavailable.
07-12-2017, 12:06 PM   #3
QuoteOriginally posted by jlstrawman Quote
i am hoping that's not the case , someone else said theirs had similar issue and was able to take it a part a clean with distilled water. I guess i'll just attempt to take it apart and see what happens.
07-12-2017, 05:06 PM   #4
QuoteOriginally posted by dcshooter Quote
Be forewarned: if you do end up taking it apart and successfully get it working, chances are it won't end up watertight when you put it back together, so I wouldn't take it snorkeling anymore...
yeah , already considered that, gonna try anyway it not doing anything for me as it is.
07-14-2017, 03:15 AM   #5
OzzRod's Avatar
Back when I used to use a Nikonos, the seals, which were much larger, had to be assiduously cleaned and have a layer of silicone grease applied every time you changed a roll, and even then, once in a while a tiny piece of sand or just a slightly mispostioned seal would lead to a flooded compartment, lost film, and a soak overnight in distilled water.
I remember those days, but if you did look after the O-rings, I found the failures were pretty rare (Nikonos II) .
07-14-2017, 03:48 AM   #6
Seeker of Knowledge
aslyfox's Avatar
related question if I may
I may be going out onto salt water with a K 3, K 5 II and/or K 1 along with several lenses some with WR rating, some not
what suggestions do you folks have for protection of such equipment, especially the lenses without WR rating
would WR be sufficient to protect the equipment from any damage/issue so long as there isn't immersion ??
would wiping it off with dry toweling be sufficient?
07-14-2017, 05:38 AM   #7
Seeker of Knowledge
aslyfox's Avatar
If you are using non-WR, I'd consider something like this.
If you are totally WR, you should be ok with salt spray. Just give it a good rinse or wipedown with room temperature water when you are done (do not submerge, of course), then towel dry. Don't change lenses unless indoors or in calm air with no spray.
A bigger concern than salt spray is sand, which can get in even with WR. If you are on a boat, it shouldn't be much of an issue, but be very careful if you are on the beach. A UV/clear filter is also a good idea to protect the front glass from pitting from blowing sand.
thanks I just chose to get this type -
Op/Tech 9001132 18in SLR Rainsleeve for Cameras
it seems to protect the camera and overall lens and leaves the actual lens and view finder clear
you get 2 units for the price no shipping fees from Aorama
07-14-2017, 05:38 AM   #8
twilhelm's Avatar
QuoteOriginally posted by Aslyfox Quote
Living in Florida, this was a real concern. But after hundreds of portrait shoots on the beach with my K10 D and many more with my K5, I've never had an issue. Plus my K10 D works flawlessly to this day. With non-WR lenses, I would blow the camera-lens off with a can of compressed air before wiping down with a damp cloth. With WR lenses I have a spray bottle of distilled water and I would mist it before wiping it down.
As the last poster said, a good filter is a must on a windy day. Much cheaper to replace than a lens.
07-14-2017, 06:25 AM   #9
Theov39's Avatar
Salt water and sand are potentially the most damaging forms of exposure that you can subject a camera to. My solution was to just buy a water proof compact camera (Nikon AW110) rather than risk my expensive equipment. However, it depends on how risky the activity is. Just taking photos from the deck of a boat or from the shore is one thing. Taking your gear kayaking is another.
07-14-2017, 07:18 AM   #10
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Theov39 Quote
we are considering going on a small tour - 8 guests - whale watching in the Sea of Cortez (California) and then crossing Baja California and staying several days on the beach at San Ignacio Lagoon
obviously I will have to be concerned about sand on the beach and then the wind/spray/waves on the 22 foot boats
07-14-2017, 11:29 PM   #11
Theov39's Avatar
I think whale watching will be fine from a boat esp as the boats tend to keep their distance. A compact camera lens will probably be too short for whale watching unless they are very close.
However, I don't take my Pentax DSLR and lens to the beach although they are both WR but that amazing video of Pentax WR gear being used in Afghanistan seems to suggest it will do just fine! YMMV
07-15-2017, 03:45 AM - 1 Like   #12
Seeker of Knowledge
aslyfox's Avatar
thanks for the help and suggestions
you are all awarded " BONUS POINTS " which you can use to buy coffee at your local diner when you add $
07-22-2017, 06:57 PM   #13
that is a very good video but at the end I saw a lens cap on the camera to your right. I don't know if it matters but I caught it. Good vid none the less
pentax service, repair, salt water, service, w90, w90 schematic, warranty
Question I no longer use PayPal......I no longer accept PayPal.....Can I still sell on PF ?? Dlanor Sekao Site Suggestions and Help 8 04-07-2016 07:38 PM
Power outage / USB 3.0 ports no longer working r0ckstarr General Talk 5 01-08-2015 05:13 PM
prime lenses no longer working alpalcargop Pentax K-r 7 09-22-2011 05:58 PM
A Sign I'm Too Immersed in Photography Mike Cash General Talk 30 03-11-2009 05:44 AM
All times are GMT -7. The time now is 03:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
