08-15-2017, 04:48 AM   #1
Pentax K-200D bottom cover seals
Hi!
I've juste changed my K-200D bottom cover... but unfortunately the old seals are irrecoverable.
So i've asked to PM2S (official Pentax repair service for France) for these seals:
Référence / Désignation / PUHT €
76830A460 / Water proof sheet 1.2X94 / 10,96€
76830A54 / Tripod screw water proof sheet / 10,96€
77050A475 / Waterproof sheet 1.2X90 /10,96€
10.96€ each, excluding VAT!!!!
Any tips to find cheaper seals are welcome
Anyone tried to cut new seals in gaskets sheets? Or maybe with liquid silicone sealant?
08-15-2017, 08:24 AM   #2
I haven't had the bottom off of my K200D, but if there isn't any obvious reason not to use the silicone sealant, personally I'd strongly consider it!
08-15-2017, 09:30 AM   #3
In the US we can't even get such parts without paying a flat price for the repair, so this looks cheap to me!
08-15-2017, 09:47 PM   #4
I don't want imagine the price for the repair with 33€(excluding VAT) just for the seals :-(
What about acetic acid emanations with the silicone sealant? Can them damage the sensor?
I've found 0.047" O'ring cord. It's exactly the same thickness as the genuine seals maybe better than liquid sealant?
08-16-2017, 02:11 AM - 1 Like   #5
Nice!
I've found and ordered 1.2mm thick insulation adhesive (1 side) neoprene roll
7€ including delivery
5m lenght, 1cm width... Genuine seals seams to be 2mm width, so in this roll I can cut a lot of new seals
08-16-2017, 07:26 AM   #6
Hopefully the neoprene works for you. I use GE Silicone II to glue FM dial plates on vintage receivers I restore. The dial plates are plastic, but the silicone has never damaged them at all, so I doubt it would hurt a sensor. If you did use silicone, you would need to be careful not to accidentally glue any wires or ribbon cables to the bottom plate. If you do, they could be damaged if you ever need to remove the bottom plate again!
08-16-2017, 08:56 PM   #7
QuoteOriginally posted by DougieD Quote
Thanks for your feedback
bottom, k-200d, pentax, pentax k-200d bottom, pentax service, proof, repair, seals, service, sheet, warranty, water
NiMH's or a battery bank for a 200D? robertbruceshaw Troubleshooting and Beginner Help 8 05-21-2016 05:59 AM
Travel Lake Bohinj-Bottom to top to bottom lukulele Post Your Photos! 4 04-25-2014 09:43 AM
p30n, taking off bottom cover Sluggo Pentax Film SLR Discussion 2 07-06-2009 02:43 PM
All times are GMT -7. The time now is 05:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
