11-13-2017, 08:41 PM   #1
DavidDwight's Avatar
60-250 SDM going bad or a different issue?
Had my DA* 60-250 for about 1.5 years. I purchased it new. Recently a few times the auto focus has stopped working. Here is what I have experienced:
Been using it for an hour or more and then all of a sudden I notice it isnít focusing. I notice it sounds like it is trying with a momentary electrical squeak. Trying to manually focus I notice the outside barrel used to manually focus is not reliably moving the mechanism (looking through the window where the focus distance shows it moves slightly then stops). After manually working the focus barrel back and forth zooming etc. and not feeling anything mechanically binding it seems to start working again....
1) do you think it is mechanical?
2) do you think it is electronic (SDM)?
3) any tests I can do to confirm?
4) where do you think I should get it repaired?
Thanks
11-13-2017, 09:00 PM - 1 Like   #2
My copy (bought used around a year ago) suffers from the same issue on rare occasion (3 times over the past year). The quick fix is to use a small screwdriver to turn the focus drive screw. Works every time. It's not the infamous SDM issue. I believe it's some issue where the clutch that engages between quick shift focus and SDM driven focus gets stuck between the two, engaging nothing and making the strange sound as a result.
11-14-2017, 05:22 AM   #3
QuoteOriginally posted by darylk Quote
Thank you- I will start carrying a tiny screwdriver and give it a try next time
11-14-2017, 12:24 PM   #4
j5m
where is the focus drive screw?
11-14-2017, 02:06 PM   #5
FantasticMrFox's Avatar
QuoteOriginally posted by DavidDwight Quote
Sounds like the infamous Pentax SDM-failure. Just google around for that term and you'll find plenty of material
11-14-2017, 02:09 PM   #6
Look at the camera mount end of the lens. On the face of the mounting ring, you will see what looks like a small slotted screw. That's it.
11-14-2017, 02:44 PM   #7
j5m
Got it. Thanks. Had this problem with my 16-50.
11-14-2017, 08:29 PM   #8
QuoteOriginally posted by j5m Quote
Good luck. I've never heard of this specific issue happening with the 16-50, i.e. hearing internal motor/mechanism sounds and not being able to manually focus in addition to auto focus not working. If your 16-50 is totally unresponsive in terms of autofocus (i.e. no sound of motor/mechanism), but still allows you to manually focus using quick shift, I suspect you may have a dead SDM motor.
barrel, focus, notice, pentax service, repair, service, warranty
Nature Going, Going, Going, Gone Kerrowdown Post Your Photos! 10 07-25-2018 01:32 PM
DA* 60-250 owners: How do you carry your 60-250 at the ready? apisto Pentax SLR Lens Discussion 25 12-30-2017 01:49 PM
Possible SDM issue on Pentax da 60-250 pearsaab Pentax SLR Lens Discussion 3 05-18-2016 05:49 AM
is the 60-250 really a 60-200 ? roro Pentax SLR Lens Discussion 25 12-19-2015 03:27 PM
All times are GMT -7. The time now is 08:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
