Originally posted by Church Key This is a really trivial matter, but thought I'd seek some advice.
I have a 50 year old Yashica 4X4 LM twin lens reflex that was a gift to my father that he never used. I ended up getting it back when he passed. I recently started back into film with a K1000 and now an LX (for which I keep buying accessories, duh). Anyhow, decided to use the Yashica as B&H has 127 film available. Started to check out the Yashica and the cover on the shutter speed setting dial, which is there only for appearance, dropped off. It is metal as is the dial; apparently the glue holding it on dried up. The residue seems to be some light tan glue.
I can just put a drop of JB weld on it, but I was wondering if there is anything better? BTW - The light meter still functions and matches my Gossen's readings.
Church Key
Contact cement would be best, but Krazy Glue or Gorilla Glue will also work just fine. Be careful with Gorilla Glue. Like all polyurethane adhesives, it tends to foam up quite a bit and can migrate outside of the repair if too much is applied.
