11-29-2017, 02:29 AM   #46
QuoteOriginally posted by yucafrita Quote
It should have been easy to screw a metal bridge or cover plate into the chassis to support the flash unit.
At the design stage, I agree that applying strength to the top element of the body would have been a good idea.
Even a body that is [carbon fibre] plastic everywhere, like the D750, has a metal top plate.
The Pentax design choice on this for the K-1/KP must have some perfectly valid engineering or manufacturing logic. But I can't see it.
11-29-2017, 05:24 AM   #47
ffking's Avatar
While it might have been prima facie preferable to extend the metal chassis to cover the hot shoe, we don't actually know whether or not this was in fact considered and if it might have been considered and rejected. It might just be another of those necessary design compromises that testing didn't show up as a problem - if it actually is a problem - does anybody know of any other instance of this occurring? Perhaps it should be classed as less ruggedness against a particular form of damage than as a weakness per se?
11-29-2017, 06:08 AM   #48
QuoteOriginally posted by ffking Quote
11-29-2017, 06:36 AM   #49
Lord Lucan's Avatar
Having worked in several engineering design offices I can assure you that is not necessarily true.
12-01-2017, 10:57 AM   #50
kjphilippona's Avatar
QuoteOriginally posted by Lord Lucan Quote
This is not good, i was planning to use my K-1 and Metz flash to take pictures at my family gathering Christmas! I tried taking pictures indoor without flash Thanksgiving with no luck : Lucky i still kept my K3
12-01-2017, 11:16 AM   #51
monochrome's Avatar
QuoteOriginally posted by kjphilippona Quote
Jus don’t put unusual lateral stress on the flash shoe. Put the camera down on its back, not propped tripod style on the side and flash head. Don’t swing it around with one hand below your waist.
You should be fine.
12-01-2017, 11:54 AM - 2 Likes   #52
Alex645's Avatar
I would not hesitate using an external flash on the K-1.
a) The Pentax flash that the OP used is very robust and weather-sealed. The Metz is not and I would expect 9 times out of 10 its foot would break before the shoe on the camera would peel off.
b) Whenever using an external flash on any hot shoe, care must be taken to not accidentally hit or put any undue stress on the attached flash unit. I wouldn't treat the K-1 any differently than a K-3, even if the K-3 has a stronger hot shoe.
c) If you use flash OFTEN, then I'd get a bottom mounted side bracket with a Pentax hot shoe adapter.
Vello CB-600 Straight Flash Bracket CB-600 B&H Photo Video
Vello Off-Camera TTL Flash Cord for Pentax Cameras (3') OCS-P3
12-01-2017, 12:03 PM - 1 Like   #53
I would not hesitate for one second using an external flash on the K-1.
a) The Pentax flash that the OP used is very robust and weather-sealed. The Metz is not and I would expect 9 times out of 10 it's foot would break before the shoe on the camera would peel off.
Thank you Alex! Even though i do not like using my flash, those two are very inexpensive and a good investment. I have them on order
12-06-2017, 02:22 AM   #54
got the cost estimate back from the repair house in Hamburg. €205,42 shipped back to me in "3 weeks or so". the top casing apparently costs €69,62, the rest is labor, shipping and taxes.
They deny any warranty coverage, they say it's caused by a fall. I know this isn't the case, but they're not going to believe me.
I'll close this out when it comes back. Waiting is the hardest part.
12-06-2017, 02:11 PM   #55
bdery's Avatar
QuoteOriginally posted by bigoak Quote
Best I can get:
You know, you COULD try to just place it back and use some adhesive to attach it properly
Just kidding, while it might work the hotshoe would probably not be very sturdy and it would certainly be ugly...
12-07-2017, 12:43 AM   #56
I will play devil's advocate. Around 30 years ago I tested a Ricoh KR-5 with it's thin plastic top cover and mounted a Vivitar 285 flash on it. It took a lot of force to get that to break. Yes, a metal top would be more durable but I suspect that something happened that the owner didn't know about.
idea, k1, pentax service, repair, service, warranty
Emperor gore vidal 3party Monthly Photo Contests 9 09-11-2017 08:23 PM
Pentax hot shoe adapter + off shoe adapter - any limits on the flashes used? MSL Flashes, Lighting, and Studio 4 10-25-2014 06:13 AM
Wanted - Acquired: Wein Hot Shoe to Hot Shoe Safe Sync HSHSB 990-560 excanonfd Sold Items 0 08-26-2010 10:56 AM
Wein Safe-Sync Hot Shoe to Hot Shoe Iowa Tom Pentax DSLR Discussion 1 09-12-2009 09:20 PM
All times are GMT -7. The time now is 02:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
