02-11-2018, 04:18 PM   #1
Pentax F 50mm f/1.4 - Auto aperture show maximum of f/4.0
Hi guys,
I've got a lens here that is showing an aperture value of f/4.0. I've had a look at this website Features and Operation of the Ka Mount and it seems to hint that there is a contact problem with the lens. I think it's a bit deeper of an issue since I've noticed signs of oxidation damage on the mount and internals when opened. I'd like to know whether a lens like this is salvageable from this situation. Read the details below if you're interested.
Details:
Lens did not autofocus when first obtained, fungus and dirt throughout. Mount had green oxidation and a patch of chrome removed with rust behind it. Two screws closest to the contacts turn freely due to previous repair attempt (it seems). Lens focus ring didn't turn freely, neither did the aperture ring. Lens disassembled and optics cleaned (to 96% original state). Focus helicoid cleaned using alcohol and re-greased. Aperture mechanism opened up and cleaned with alcohol. Focusing position forks (the fragile 4 pin ones) cleaned as they were heavily covered with blue-green oxide layer. Lens reassembled and focusing now working. Max aperture showing as f/4.0 unless the lens is flexed while on camera, in which case it flickers between -- and f/4.0. Aperture value of f/1.4 comes up for a split second before f/4.0 holds. Stopped down aperture value of f/22 shows up as required. Lens overexposes by 3 stops if shooting an image at f/4.0, as the camera meters for f/4.0 but lens is shooting wide open.
Thanks in advance!
02-12-2018, 01:26 AM - 1 Like   #2
Q: What camera body are you using?
I ask this question as I coupled by K3ii to my F*600mm on the weekend and had F-- feature. Perplexed, I re-coupled the lens to my K-1 and found no trouble.
02-12-2018, 05:04 AM   #3
QuoteOriginally posted by Wild Mark Quote
I've used the lens on both a KP and a K-1. All other lenses operate as normal so it's almost definitely a lens problem. The main culprit is probably the aperture flex board (if there is one) or possible corrosion of wiring in the lens. I could probably open the lens up even more to expose the wiring but I don't see the point unless someone else has had experience of it previously.
It's a really weird situation in that I've got an autofocus 50mm f/1.4 with only manual aperture. A bit like taking a K 50mm and putting a screwdrive unit in it.
02-12-2018, 05:33 AM   #4
blende8's Avatar
Just to make sure:
- the aperture ring is set to "A".
- the largest opening you can set on the camera is f4.
Is that right?
02-12-2018, 10:38 AM   #5
QuoteOriginally posted by blende8 Quote
Just to make sure:
Is that right?
Correct as of yesterday... I tried the lens today and I'm getting correct aperture behaviour on my K-1, with rough/slow focusing.
On my KP, the focusing is better but the higher apertures do not stop down properly. Even stranger behaviour...
50mm f/1.4 auto, aperture, camera, f/1.4 auto aperture, f/4.0, lens, mount, oxidation, pentax f 50mm, pentax service, repair, service, value, warranty
What maximum ISO to use on K-70 default auto ISO range? OldChE Pentax K-70 7 02-19-2018 08:01 PM
Aperture control problems with variable aperture lenses (with aperture rings) gtxSeries Troubleshooting and Beginner Help 3 09-13-2017 01:11 PM
Pentax K-1 maximum dynamic range - winner beholder3 Pentax K-1 8 05-13-2016 12:13 AM
Pentax K-50 maximum payload? Helios 1984 Pentax DSLR Discussion 15 04-08-2016 07:19 AM
For Auto ISO, what is your maximum setting? bladerunner6 Pentax K-30 & K-50 33 12-14-2014 09:24 AM
All times are GMT -7. The time now is 09:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
