03-15-2018, 10:45 AM   #1
Need DA* 16-50mm weather seal band
Hi there,
I am looking for the weather seal bands, especially the very thin one at the zoom ring, does anyone know where I can get it ?
03-15-2018, 01:23 PM   #2
UncleVanya's Avatar
Somewhere on the site was a list of repair centers - outside of just the warranty one there were others that could order parts too. I'm trying to remember how to pull up the list. If I read your profile correctly you are in Hong Kong - this is old (11 years old!) but might be a lead worth checking into: Digital Camera Repair | Forums- Hong Kong Advice | Hong Kong Expat Forums | AsiaXPAT.com
03-15-2018, 05:08 PM   #3
Thanks but the repair cost is too high especially Pentax is not a hot brand here, the task is quite easy so I would rather do it myself.
03-15-2018, 08:20 PM   #4
UncleVanya's Avatar
QuoteOriginally posted by lotech Quote
I was suggesting that this contact may be able to get the parts for you.
03-15-2018, 08:48 PM   #5
Thanks, I will start googling Japanese websites to look for it, and there may be alternative if I know the spec of the band.
03-23-2018, 08:49 AM   #6
This is what I was talking about, the 2nd piece just fall apart, now the zoom ring becomes very loose
LG-H990  Photo
03-23-2018, 04:21 PM   #7
Ex Finn.'s Avatar
Most likely a JIS size o-ring. I would remove it and get measurements.
O-Ring Size Charts - Metric O-rings - Standard Size O-rings
03-23-2018, 04:28 PM   #8
Seeker of Knowledge
aslyfox's Avatar
be advised that it is said if you need to remove the screws on a Pentax lens or camera, you need JIS screw driver
Cross-head screws - a caution: - PentaxForums.com
https://www.pentaxforums.com/forums/8-pentax-film-slr-discussion/181187-my-c...endations.html
03-23-2018, 04:38 PM   #9
Ex Finn.'s Avatar
QuoteOriginally posted by Aslyfox Quote
My camera tools reccomendations. - PentaxForums.com
And they used lock-tite, at least on the body screws.
03-23-2018, 05:09 PM   #10
mee
You can still get the screws with a basic jewlers screwdriver, just be aware you could potentially strip the screws. It would be very difficult but the risk is there.. Also tape the tops of your contacts as they are spring loaded.. once you release the screws and lift the mounting ring, they could go flying... and they're tiny. So lift slowly..
I tried for MONTHS and months and months to get a DA* 50-135mm O ring ...no one had them.. so I don't think they're easy to obtain sadly. One other route, beyond repair services, is to buy a junk used copy and just strip it for parts.
05-11-2018, 09:55 PM   #11
QuoteOriginally posted by mee Quote
I opened the lens couple times tried to fix the SDM but unsuccessful and I gave up, the lens is still working great and very sharp, only little loose on the focus and zoom ring, I won't bother try to fix the seal again, I will keep using it until I upgrade to FF.
---------- Post added 05-12-18 at 01:02 PM ----------
Thanks for the tip, but I can't get the exact measurement coz it already broke into pieces.
QuoteOriginally posted by Ex Finn. Quote
da* 16-50mm weather, lens, months, pentax service, repair, screws, service, size, strip, warranty, weather
weather seal on program selection dial?? 49tandrew Pentax K-3 4 01-28-2017 11:17 AM
AA bats & weather seal.. list help bobva Pentax DSLR Discussion 6 05-17-2011 02:00 PM
People Strike Up The Band - (6th Grade Band) atupdate Post Your Photos! 4 12-12-2010 06:48 PM
Sigma 70-200mm f2.8 or Pentax 60-250mm f4 ? seal or no seal? TanGU Pentax SLR Lens Discussion 15 09-27-2010 03:12 AM
Has anyone tried to weather-seal their lenses? drec Pentax SLR Lens Discussion 7 05-20-2009 11:46 PM
All times are GMT -7. The time now is 02:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
