Originally posted by dMwBennn Does it matter? Looks like the door still closes.
Originally posted by Theov39 From a technical viewpoint, probably not as it appears that the seal over the SD card slot is unaffected BUT I don't like the way it looks and would prefer to fix it if possible.
Originally posted by Kozlok Epoxy putty may also work, but something that requires a bit of practice.
Honestly, I think any repair is going to look like a repair, and you could end up making it worse. Epoxy is versatile as it can be sanded into shape precisely once it has fully cured - but, it's not going to be an easy job, and you'd need to sand it level to the surrounding material which would probably remove paint in those areas, leaving an even more to touch up with paint (which won't exactly match the finish on the rest of the camera). Plus, the risk of getting dust from the resin inside the memory card slots would be quite high.
Personally, I would just live with it. It's always disappointing when you mark or damage a piece of equipment, but the initial disappointment fades in time - especially if you think of the camera merely as a tool rather than a valued possession; and that's all it is, really. Professional photographers don't worry about the cosmetics of their cameras for that very reason.
