Originally posted by Not a Number From the sample in the lens review database I'd guess it was just glued on in the first place.
I wouldn't use superglue as it will out gas and fog up the window permanently.
Acetone will only work on ABS, PLA, PCV and like plastics. It's so thin it is difficult to get it to go where you want without spreading. The acetone might attack the cement between lenses in groups.
Maybe a polyurethane glue like clear Gorilla Glue.
I used Gorilla Glue a year ago and it broke off again. So I have decided to try something else.
Just took the chance of using minute amount of superglue and it worked like a charm. The windows was only slightly fogged, but completely usable. The glue also feels stronger than Gorilla Glue.
---------- Post added 04-15-18 at 12:27 PM ----------
P.S. I asked a friend of mine who is a chemistry major and he said that once the superglue cures, nothing will evaporate because the product is a polymer similar to most other plastic.
---------- Post added 04-15-18 at 12:28 PM ----------
Originally posted by marcusBMG I've been using this stuff to weld polycarbonate (perpsex type stuff) sheet and other things, like a router bit box made of clear plastic simiar in kind to what you wnat to glue:
Model X Pro 50ml PLASTIC WELD Cement Glue Styrene ABS Perspex Acrylic | eBay
It works great! Whether it will work on the plastic used for the tamron lens window will depend on what type of plastic it is precisely, but in general terms acrylic like plastic is exactly what this is for.
This one seems to be similar to my green bottle Tamya plastic cement, which AFAIK is mostly acetone. I actually use the fluid to clean up any excess superglue residue, with a Q-tip.
