04-25-2018, 06:49 PM   #1
Pentax Super A/Super Program camera base plate
Sorry for the double posting but realized my question should probably be placed here rather than in the film SLR section
Does anyone know if the base plate from another Pentax camera model (e.g. the M series) will fit a Pentax Super A/Super Program camera?
I bought one but the base plate is quite dented and I would like to replace it. If other camera bodies can also be used that will make it easier.
The Super A basically uses the same body as the Super ME and the base plate appears almost the same except for the winder contact points.
Thank you
Theo
04-25-2018, 07:22 PM - 1 Like   #2
c.perkins's Avatar
If the camera functions as it should, I would just roll with it.
It is called character marks.
You know what will happen if you replaced the base plate with a new one, don't you
Clarence
04-25-2018, 08:15 PM   #3
QuoteOriginally posted by c.perkins Quote
Clarence
I think you are right. Where do you stop once you start?
The impression in the base is actually from a tripod so either the metal is very soft or the previous user very strong! I gave the camera a good CLA myself and everything appears to be working as it should.
04-25-2018, 08:34 PM   #4
pschlute's Avatar
I noticed that the baseplate of my Super-A was "missing" the winder cover. After a bit of research i concluded that the model was never supplied with one. Does yours have one ?
I am referring to the circular hole in the baseplate where the battery powered winder mechanism would connect to.
04-25-2018, 08:53 PM - 1 Like   #5
Attached is a photo of my camera's base plate. There is no cover over the winder mechanical connection.
The electrical connections are circled in yellow. Also no cover.
Canon PowerShot S100  Photo
04-26-2018, 02:53 PM   #6
UMC
UMC's Avatar
No, Super A / Super program had neither a cover for the winder coupling nor anything that covered the contacts. Interesting though that the earlier ME Super did have a winder cover.
a/super, a/super program camera, base, camera, pentax, pentax service, pentax super a/super, plate, program, program camera base, repair, service, warranty, winder
Pentax Super A/Super Program base plate Theov39 Pentax Film SLR Discussion 1 04-25-2018 09:23 PM
Spotmatic: acidic or basic chemical cleaning of base plate ? landstrykere Pentax Film SLR Discussion 12 03-20-2018 10:13 PM
For Sale - Sold: Pentax K1 Really Right Stuff Base and L-Plate Qwntm Sold Items 2 05-31-2017 10:58 AM
anyone know where i can get MX base plate screws? JDaughtry Pentax Film SLR Discussion 5 08-08-2011 08:34 AM
All times are GMT -7. The time now is 04:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
