Originally posted by jpzk
"If it ain't broke, don't fix it " !!
My guess: if it hasn't caused any problem(s) it will likely not.
More members will come in and give more information, I'm sure.
What's what I'm trying to figure out. Don't want to send it for repairs if not needed, but don't want it to fail when I need it the most!
---------- Post added 06-06-2018 at 04:36 PM ----------
Originally posted by stevebrot
You might contact the seller to see if they have any information on the camera's history. Was the camera sold to you as new or used? In regards to the CS representative, you can send them this link:
Ricoh offers fix for Pentax K3 II power-off problem
I have no idea whether there is a flag in the EXIF indicating whether the service had been performed, though there may be a few clues such as whether the serial number in the EXIF agrees with that on the body or whether the manufacture date is after the recall date.
Good luck
I'll ask the seller. It came from Canada (eBay) and it's a very early serial. 04/25/2015 mfg. date 618xx SN
---------- Post added 06-06-2018 at 04:38 PM ----------
You can always attempt to provoke the symptoms by leaving the battery out for several days/weeks as described in the notification.
Might try that once I get back from vacations, though I don't want it to be sitting unused for a month (or more?) if I can be using it instead!
---------- Post added 06-06-2018 at 04:42 PM ----------
Originally posted by Adam
Definitely see if you can provoke the behavior. If not, then chances are it's either been fixed or happens to be fine.
If it turns out a repair is necessary, contact Ricoh and provide them with all the necessary documentation/info about the recall; they will likely hand you off to precision. Phone would probably work best in this case since the explanation might get tricky.
I'll try once I get back from vacations, but I want to make sure I can send it for repairs once I make it fail, although it might be ok, since having only ~100 shots since 2015 has me thinking it could have been with no battery or fully drained battery for a while.
