Originally posted by monochrome Your viewfinder stopped working? It is a piece of glass. Was the mirror in the UP position?
I meant that there first was garbage (values that did make any sense) in the viewfinder display. Then it went completely dark. After a day or so the correct information appeared in the viewfinder.
---------- Post added 07-16-2018 at 11:30 AM ----------
Originally posted by 08amczb Push the info button, to turn on the monitor. Playback and menu should work regardless you disabled the monitor or not.
If you think water may get in to the camera you should dry it first, and check these tomorrow. (My KP get some water on Saturday with a WR 18-135 lens, so it can happen! Now it works again.)
Thanks. I tried this but the monitor doesn’t respond. I was using WR lenses also.
