08-01-2018, 01:22 PM   #1
K-1ii Upgrade and AF Fine Adjustment
Has anyone who has done the upgrade checked to see if the AF Fine adjustment for their lenses has changed?
Thanks.
08-01-2018, 01:26 PM   #2
MarkJerling's Avatar
QuoteOriginally posted by kthornsberry Quote
Thanks.
As the upgrade is a new main board, you'd be receiving back an (effectively) new camera. Any pre-sets / settings modifications will be gone.
08-01-2018, 02:03 PM   #3
BigMackCam's Avatar
I would expect any previously-stored adjustments to be gone...
That said, the physical position of the phase detect AF sensor shouldn't have changed, so if you've noted down the relevant AF fine adjustments for each of your lenses, I think there's a good chance that they'll still work. If it were me, I'd start with those original adjustments and carry out tests to confirm they're still accurate.
08-01-2018, 02:48 PM - 1 Like   #4
Thanks, BigMacCam. That's my situation. I have a spreadsheet with the calibrations for all my lens/body calibrations. I'll eventually get them all redone, but I'm just curious if anyone has gone down this road and checked to see if they changed. I'm heading out this weekend and won't have much time to recalibrate before I go.
08-01-2018, 03:19 PM - 2 Likes   #5
Upon upgrade I lost all of the autofocus adjustments and had to re-enter them. Most of the adjustments were spot on when tested after re-entering them so no big deal. BTW, loving the upgrade so far.
08-01-2018, 08:50 PM - 1 Like   #6
Journeyman Cat Wrangler
SSGGeezer's Avatar
QuoteOriginally posted by Pentax Syntax Quote
That is good to hear! You should list how the camera's behavior has changed and what is the most important change you have found.
08-01-2018, 08:58 PM   #7
Thank you.
08-28-2018, 06:23 AM   #8
Got mine back yesterday, as others all the settings were lost. They CLA'd the body as well as the upgrade. Any of the autofocus adjustments stemming from the body would likely change. I think it did with mine, going to check with the scale today.
adjustment, af, autofocus calibration, k-1ii, pentax service, repair, service, upgrade, warranty
Upgrade or Trade K-1 In for K-1II wanderer2 Pentax K-1 14 03-14-2018 10:37 PM
K-S1 + AF Fine Adjustment + Sigma stv Pentax K-S1 & K-S2 9 05-30-2017 11:52 AM
Question for owners of K-3 / K-3II *and* K10D / GX-10 re AF fine adjustment BigMackCam Pentax K-3 8 10-24-2016 07:13 AM
All lens needs AF fine adjustment, does the camera need a global adjustment? Thanks bennyxyz Troubleshooting and Beginner Help 9 04-21-2016 12:36 PM
AF Fine Adjustment, focus correction, AF micro adj., AF fine tuning annajonna Pentax K-5 13 11-19-2011 11:32 PM
All times are GMT -7. The time now is 05:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
