08-05-2018, 10:36 AM   #1
Pentax Asahi KM Battery Compartment Malfunction
Hello,
A couple of days ago my brother bought a Pentax Asahi KM at a fleemarket for 5,-. We weren't certain if the camera would work, and so far we have yet to test it. However, we have tested the exposure meter, and this refuses to work. This is probably due to a flat battery, unfortunately we were not able to remove the battery without unscrewing the camera's bottom housing. After unscrewing said housing we were able to successfully remove the battery! Unfortunately we found out that the battery compartment isn't functioning properly. We removed the piece that holds the battery's contact leaf, as you can see on one of the photos. This piece is unfortunately quite damaged. We were wondering if anyone could tell us what the part is called and how to get a hold of it. We also checked the internet for a service manual for the KM, but without luck.
Any help would be greatly appreciated!
IPhone 7  Photo
IPhone 7  Photo
IPhone 7  Photo
IPhone 7  Photo
09-25-2018, 05:30 AM   #2
QuoteOriginally posted by Phulax Quote
Hello,
Hi,
You may as well look for the Spotmatic repair manual, as most of the KM is equal to the Spotmatc F, except for the K-mount.
From the pictures it seems that you should just reconnect the wire on the back of the battery holder. That is difficukt to solder while the lip is stainless steel. You can use conductive glue instead.
The Battery caps can get terribly locked on the bottom plate. Quite an adventure to open them and from your last picture it's obvious somebode tried it before you! First remove the bottom plate from the body before exercising brute force. You might use penetrating oil and leave it for a week. As the cap is damaged already you can pry in a screw driver.
You might consider th keep the cap stuck and remove the bottom plate to change batteries!
Success!
Wim
asahi, asahi km battery, battery, compartment, km, km battery compartment, pentax, pentax asahi km, pentax service, piece, repair, service, warranty
Pentax LX battery compartment jcs0001 Pentax Film SLR Discussion 20 01-12-2019 09:30 AM
Battery Compartment Door is Stuck shut on my ist PentaxBirdLady Repairs and Warranty Service 15 02-10-2018 08:57 AM
Pentax ES II Battery Compartment iht Pentax Film SLR Discussion 7 10-26-2012 08:03 PM
Pentax MV Battery Compartment... eniceeleven Pentax Film SLR Discussion 2 08-23-2011 02:55 PM
Battery compartment issue john_ven24 Troubleshooting and Beginner Help 8 01-31-2009 07:41 AM
All times are GMT -7. The time now is 03:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
