before working on your lenses or camera, perhaps you might want to look at this thread:
Cross-head screws - a caution:
Posted By: pacerr, 10-22-10, 11:03 (Offline)
Those screws that look like Phillips 00 and 000 in Japanese cameras and lenses? They aren't. They're JIS cross-heads and life's a lot simpler using JIS screw driver bits on 'em.
Whether you do this only once and run into trouble, or intend to do it often, it's worth your sanity to do it with the correct JIS tools so you don't risk stripping a screw head. T-shirts should be available for those that have been there, done that!
Sooner or later, you'll be sorry if you don't use the JIS bits since the Phillips bits make great roto-rooters in JIS screw heads because they don't fit all the way into the cross slots as you can see here:
Read more at:
Cross-head screws - a caution: - PentaxForums.com
