01-19-2019, 03:12 PM   #1
77 LTD disintegration
So was shooting some portraits and it started making a high pitched af noise. Wasn't sure the issue, so went to change lenses to my dfa 100 to keep shooting and it just kind of... disintegrated. K1 is fine, I'm not sure how to proceed.
Purchased used from the marketplace. Any ideas for fixing?
I do travel fairly often, but use a nice bag and soft pouch.
CONUS btw
Pixel 2 XL  Photo
01-19-2019, 03:24 PM - 1 Like   #2
Seeker of Knowledge
aslyfox's Avatar
Precision Camera in Connecticut
http://www.precisioncamera.com/
will work on Pentax lenses even if out of warranty
I recently had Precision repair my DFA *70-200 F2.8mm, it had no warranty
sent it in for free estimate of repair ( you pay postage to them and return postage ) and decided to have it repaired, it had to go to Japan
has worked flawlessly since I got it back
check out this thread:
US Pentax Warranty Repair Information - PentaxForums.com
______________________________________
also check this thread, it does list US companies that do repairs:
Pentax Repair Facilities (Wordwide listing) - Page 8 - PentaxForums.com
good luck
01-19-2019, 03:41 PM - 1 Like   #3
Digitalis's Avatar
I had this happen to me with my copy of the FA77, it is a quick inexpensive problem to fix. I haven't had a problem with the lens since.
01-19-2019, 04:01 PM - 1 Like   #4
Eagle94VT's Avatar
*gulp* Well I hope mine doesn't pop off like that *gulp*
01-19-2019, 07:32 PM - 1 Like   #5
Docrwm's Avatar
After looking at you pic of the situation I thought you meant the lens changed to a 100mm
01-20-2019, 12:39 AM - 1 Like   #6
UncleVanya's Avatar
This thread should be marked NSFPP...(not safe for Pentax photographers...)
01-31-2019, 09:25 AM   #7
The least I could expect to pay is $350. I paid $650 for this. Thanks precision camera!
Unbelievable. Look for the rest of my kit on the marketplace. At least Sony doesn't claim to be robust before their customer service digs the knife in.
03-27-2019, 04:59 AM - 4 Likes   #8
Lens Hoarder
monochrome's Avatar
So to recap, you bought a used lens, it came apart in a fashion that we’ve seen before a few times for this lens, the repair at Precision costs 1/2 what you paid for the used lens - and now you have an internet jumping-ship rant against Pentax.
As Digitalis wrote easy inexpensive fix, but Precision has a minimum charge just to open your box. Look elsewhere for a repair, such as Advance Camera.
03-27-2019, 05:43 AM - 1 Like   #9
Seeker of Knowledge
aslyfox's Avatar
repairs are not cheap
I didn't like what it cost to repair my no warranty " experienced " D FA *70-200mm bought from a member via the market place
Precision even had to send it to Japan
but it was less than buying new or even buying another " experienced " lens and I knew the cost of repair before I authorized the repair
my choice
one would think the OP had the similar choices repair at a certain cost or not
I'm with monochrome why complain ?
03-27-2019, 06:21 AM   #10
Do look at alternatives to Precision. It can't hurt to ask and it might save you a lot. Alas, the one person I would recommend seems to no longer be in the business.
03-27-2019, 06:25 AM   #11
Seeker of Knowledge
aslyfox's Avatar
the OP was given a link to other possible options:
03-27-2019, 06:25 AM   #12
UncleVanya's Avatar
I can see the disappointment and shattered faith. The lenses look very durable and the all metal external construction implies the kind of durability that the older M and K series lenses had. It is true that repairs to the lens are cheaper than buying new but by the time you add up buying it used and repairing it, the cost starts to climb into new lens territory. It can feel very frustrating.
However...
None of the brands are very good. I have shot Canon lenses that locked up while zooming. I have shot Nikons that just refused to trip the shutter. I have seen people complain about the lack of quality in every brand imagined.
Sadly the world is not about the durability and reliability that it used to be. Disposable items are too common and ease of repair is not part of the design process these days.
03-27-2019, 06:27 AM   #13
Seeker of Knowledge
aslyfox's Avatar
. . . .Sadly the world is not about the durability and reliability that it used to be. Disposable items are too common and ease of repair is not part of the design process these days.
I remember " small appliance " repair shops as a kid
no more as far as I can tell
03-27-2019, 06:33 AM - 1 Like   #14
UncleVanya's Avatar
QuoteOriginally posted by aslyfox Quote
I do my own repairs on small appliances and even some large ones. I just repaired my $2500 (in 1998!) Kitchenair fridge. The door dispenser switch for ice was bad. When it first happened the ice ran and wouldn't stop! I had to disconnect the interior door switch to make it think the door was open and then disable the light bulb to keep from melting things near it. Then weeks later I was able to finally locate the micro switch required to make the repair. In the meantime the fridge looked like a robot in mid-repair. To get water you'd open the door, reach in and push the door switch and squeeze the panel switch (which was disconnected from the lever on the dispenser. I think my family thought I was nuts. The labor costs for a repair tech were outrageous for what was actually required.
05-22-2019, 01:51 PM   #15
Precision camera said just under $300 for repair. it's in japan getting serviced now.
pentax service, repair, service, warranty
FA 43 ltd vs FA 77 ltd, Wide Open BruceBanner Pentax SLR Lens Discussion 85 03-13-2019 11:47 PM
For Sale - Sold: Set of 3 Silver Amigos 31 ltd, 43 ltd & 77 ltd Mikesul Sold Items 0 11-01-2018 01:34 PM
For Sale - Sold: DA21 Ltd, DA40 Ltd, DA70 Ltd, plus Ltd Case rfortson Sold Items 19 11-09-2012 06:24 PM
All times are GMT -7. The time now is 01:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
