Originally posted by Paul the Sunman Do you know what exactly is broken?
The usual alternative to the Tamron 90 is the Pentax 100mm macro (several versions). They are generally regarded as having comparable IQ. If you were looking for a used replacement, I would factor in that option as well.
Nope, not sure what is broken. I wasn’t able to touch base with the guy who sends the lenses to the manufacturer, just a message about what it would cost. I am considering the Pentax 100. I didn’t love the Tamron, not sure why, it’s a great lens. Thanks for you response!
---------- Post added 01-29-19 at 07:34 PM ----------
Originally posted by pentax360 I have the older non DI version that I got for $150 and I love it.
From what I've read it may actually be more reliable too, I saw many complaints on the push pull manual/auto selector not working with the DI and none with the older model.
Thank you!! I will look into and consider this one as well. I could see the reason for the complaints, I didn’t like the push pull selector personally.
---------- Post added 01-29-19 at 07:35 PM ----------
Originally posted by mikeSF I have a broken one that could possibly used for donor parts depending on what is broken with yours. PM me and I'll help if I can.
Thank you very much for this offer! They sent it to the manufacturer and I don’t know what is broken. I’ll get in touch if I make an alternative plan that might require a donor lens. Thanks again!
