Show Printable Version 6 Likes Search this Thread
02-06-2019, 01:28 PM   #1
My K1 shell is cracked. Will Precision Camera replace that?
So a few weeks ago I dropped my K1 right on its head onto solid concrete. A large shard out of the shell and a cracked pentaprism are all the damage i've found. Still works but I obviously need to get this repaired.
If you're in the US, PrecisionCamera is the only official repair service for Pentax. I havent had a problem in the past. I know they charge a flat fee which used to be $200 the last time I used them, but has since increased to $350. Ugh.
Does anyone know offhand if they do body repairs? A large piece would have to be replaced entirely, and they don't seem to respond to questions until you actually pay them and send them your gear.
02-06-2019, 01:31 PM   #2
I've certainly seen users send them lenses with broken barrels, so as long as you're paying, I don't see why it would be any different with the camera body.
They are supposed to give you a final quote before charging you if the price differs, however.
02-06-2019, 01:45 PM   #3
twilhelm's Avatar
I had an acquaintance who did something similar to their K5 and had Precision do the repair. So I know they are able to, the cost though, I have no idea.
Good luck!
02-06-2019, 02:02 PM   #4
Not a Number's Avatar
The only way you are going to get an estimate is to send the camera in for inspection. Precision won't charge you until you approve the repair and they are ready to ship camera back to you. Replacing the top cover and pentaprism shouldn't be a problem. Checking the rest of the mechanisms for shock or G-force damage will take some effort. You'll probably have to wait for parts from Japan.
Since it is not warranty work you can try another authorized service such as Advance Camera in Oregon. They might end up sending it to Precision though if it isn't something they can handle.
02-06-2019, 02:03 PM - 1 Like   #5
madbrain's Avatar
I had damage on my K-1 II shell as well, but more minor. The quote for replacement was a total of $439.04 :
Labor : $200.21
Parts : $193.84
Shipping : $45
I didn't have the work performed in my case. The quote was purposes of getting my insurance to pay for the damage. I was without the camera for over a month.
02-06-2019, 02:04 PM - 1 Like   #6
Paul the Sunman's Avatar
Ouch! Commiserations and good luck.
02-06-2019, 02:32 PM - 1 Like   #7
Docrwm's Avatar
Epoxy is your friend.......
02-06-2019, 02:53 PM   #8
QuoteOriginally posted by Docrwm Quote
The pentaprism is also shattered. AF still seems to work fine, though.
---------- Post added 02-06-19 at 02:54 PM ----------
QuoteOriginally posted by madbrain Quote
Labor : $200.21
Parts : $193.84
Shipping : $45
Insurance... now that's something I should have looked into a long timr ago!
---------- Post added 02-06-19 at 02:55 PM ----------
Fo you think at this point I should just have the shutter replaced as well while they have it? I've already had the camera over 2 years and use it pretty regularly.
02-06-2019, 03:03 PM - 1 Like   #9
Docrwm's Avatar
QuoteOriginally posted by nzondlo Quote
Sorry to hear that, must be a mess. Sounds like repair is the only viable option.
02-06-2019, 03:37 PM   #10
MarkJerling's Avatar
[/COLOR]Insurance... now that's something I should have looked into a long time ago!
This is most certainly something you want to lay in your insurer's lap. Good luck!
02-06-2019, 06:23 PM   #11
I assume the D-FA 50/1.4 is fine. Otherwise...
02-06-2019, 07:15 PM   #12
QuoteOriginally posted by hyyz Quote
Oh yeah she's fine. All things considered. This kit has suffered a lot of drops and given me no problems. This time was just squarely on its head with all its weight.
02-06-2019, 07:41 PM   #13
I would hazard to guess the shutter and sensor are the two most expensive parts in the camera and the labor involved replacing them extensive. Replacing the shutter might push the estimate towards the not economical range (replace rather than repair).
02-06-2019, 09:22 PM - 1 Like   #14
UncleVanya's Avatar
How many shots? You can have a k-1 mirrorless if you can choose to only use live view...lol.
02-10-2019, 07:23 AM   #15
Unregistered User
Guest
I'd bought a used lens from B&H that they said was a "10" - like new. One of those fairly long and heavy lenses that requires a foot to mount on a tripod. Their warranty at the time on used stuff just said "90 days return", unconditionally.
So I'd taken the thing off the tripod after its first use and was holding the camera by a wrist-strap when the lens fell off the camera. The reason it had fallen is that the metal mounting plate in the back of the lens was missing two of the five screws that were supposed to hold it on the back of the lens. I discovered that when I removed the mounting plate from the camera, since the other three were still there.
Got an RMA from BH and they assured me it was eligible for return or repair. Sent it in (at my own expense), but they sent it back after a few weeks unrepaired, saying that it was not eligible for return because it had fallen. Well, DUH!!! They tried to persuade me that the fall had CAUSED the defect in the mounting plate. They went through all sorts of sophistry about it, but that was the bottom line - absolutely dishonest in my opinion, simply because it was going to cost them money they didn't want to have to spend.
I sent the lens to Precision, and they fixed it. I hadn't sent them the parts that had become separated from the lens (evidence), so they had to order stuff, slow boat from Japan, or something. Cost me almost five hundred bucks, but the lens is now probably better than new. Bottom line, yes, Precision will replace parts. Costs extra, though, since they apparently don't stock anything that's not commonly required. (And, by the way, I'll never buy any more used equipment from B&H.)
camera, damage, k1, k1 shell, pentax service, pm, post, quote, repair, service, shell, warranty
So, I'm supposed to send my camera to these people...? (Precision Camera) zazism_rx Pentax K-1 & K-1 II 23 02-24-2018 01:58 PM
cracked mirror pentax K-r - DIY replace?? marcusBMG Troubleshooting and Beginner Help 3 04-13-2014 12:22 PM
Cracked filter: replace or not? wedge Pentax SLR Lens Discussion 5 03-11-2014 08:46 PM
Shell within a Shell Beachnutt Monthly Photo Contests 0 01-31-2009 01:32 PM
Repair referal 100d replace cracked lcd spb37 Pentax DSLR Discussion 6 05-26-2008 12:46 PM
All times are GMT -7. The time now is 12:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
