06-06-2019, 04:28 AM   #1
Pentax Spotmatic missing screw
Hi all, I hope I'm posting in the right place. I've just discover one of the screws on the base plate of my Spotmatic is missing. Does anybody know what type of screw it is so I can source a replacement?
06-06-2019, 05:54 AM   #2
Unscrew the second screw on the other side and measure it - diameter, length and thread pitch. Or take it with you for a sample, but not lose it.
And then we look for it, for example, in specialized stores or where repairs are made to the camera.
I would do that.
06-06-2019, 07:33 AM   #3
It is a 2mm screw that is 3.5mm long. The service manual doesn't state the thread pitch but is is a common machine screw thread pitch.
06-06-2019, 09:02 AM   #4
thanks for the pointers, I'll see what I can find
06-06-2019, 09:05 AM   #5
Otis Memorial Pentaxian
It is unlikely that the existing cross-head screw is original, given that the screws flanking the tripod socket are slotted. I would not use it as an example for replacement.
06-06-2019, 09:17 AM   #6
Pentax used cross point screws on later Spotmatics. The later screws are interchangeable with the older screws in the bottom cover. If you get a screw from a K1000 with a metal bottom cover, it will fit.
06-06-2019, 01:52 PM   #7
QuoteOriginally posted by pentaxus Quote
Yes, Pentax moved to JIS in about 1970 and I have examples of both, but one does not typically see both types mixed on the same body. My caution regarding the cross point screw was that it may not be a good reference for diameter/length in that it was probably not original to the camera.
06-06-2019, 07:13 PM - 1 Like   #8
Not a Number's Avatar
I believe the screws should be counter sunk (tapered heads). Various service manuals show the screws to be chrome plated M2.0 × 3.5. Screws this small have a standard thread pitch so usually none is given.
Microfasteners has M2 × 3mm and M2 × 4mm. You could get the 4mm and file it down to 3.5mm
FMSP2004 - M2 x .4 x 4mm - Flat Head Machine Screws - Phillips - Stainless - Micro Fasteners
FMSP2003 - M2 x .4 x 3mm - Flat Head Machine Screws - Phillips - Stainless - Micro Fasteners
As does metricscrews (much less expensive)
https://www.metricscrews.us/index.php?main_page=product_info&cPath=98_5_24&products_id=32
http://www.pentax-manuals.com/manuals/service/servicemanuals.htm
Edit: the various Spotmatic parts lists refers to the screws as "saucer medium" which I take it are equivalent to pan head screws in which case any of these should do:
https://www.metricscrews.us/index.php?main_page=index&cPath=98_5_340
The screws on my Japan made K1000 are definitely countersunk.
Note: the screws by the tripod socket on the Spotmatics are m1.7 × 2.2
06-12-2019, 01:36 AM   #9
So an update, I measured the pitch at 0.4mm. I've just recieved some M2 X 3mm Slotted Countersunk Screws (DIN 963) - A2 Stainless Steel from Accuracy. Delivered. | 500,000+ Components | AccuŽ. Does the job but sits a little proud.
IPhone 7 Plus  Photo
06-12-2019, 08:39 AM   #10
QuoteOriginally posted by chasinglemons Quote
Is the hole on the camera bottom countersunk (funnel shaped) or not? If not a pan or wafer head screw would probably be a better fit.
baseplate, pentax service, pentax spotmatic, repair, screw, service, spotmatic, warranty
[Pentax MX] Screw specifications for "bottom main gear screw" papasouzas Pentax Film SLR Discussion 3 03-24-2019 11:25 AM
Where to buy a screw for Asahi Spotmatic? vyoufinder Repairs and Warranty Service 4 03-25-2018 08:36 PM
Missing screw. crayboy Pentax K-5 9 03-02-2018 10:44 AM
Repair Cost for DA15mm Missing Focusing Screw Halide Repairs and Warranty Service 6 10-28-2016 03:50 AM
Screw driven AF cameras. More high end = better screw drive? Reportage Pentax DSLR Discussion 13 09-01-2011 08:38 AM
All times are GMT -7. The time now is 07:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
