06-22-2019, 08:11 PM   #1
Pentax MX Base Plate Screws
Hello! Does anyone know the size of the JIS screws on the base plate of the MX. I'm missing just one screw, and am trying to source the correct screw. Thank you!
06-22-2019, 09:03 PM - 1 Like   #2
Not a Number's Avatar
According to the service manual (just do a search on Pentax MX service manual) the bottom screws are nickel plated stainless steel 1.7 2.2 mm screws. You'll have to look at the opening but most likely they are flat head (counter sunk).
You're not going to find JIS screws outside of Japan and I've yet find a website that sells them. The best you're going to do is Phillips head or slotted.
You're also going to be hard pressed finding 2.2mm long screws. You can always buy longer and file them down. Just don't go shorter than 2.2mm.
06-23-2019, 04:39 PM   #3
Dang, sounds like a ball breaker. Thanks for the info!
06-23-2019, 08:03 PM   #4
can you remove one of the other screws and post a couple of photos so I can see the head on it. May be able to find something close....as small ones like these may be close to what is used to repair eyeglasses. Just a guess.
06-24-2019, 10:37 AM   #5
This company has m1.7 3mm flat head screws, and pan heads at 2.5mm. A screw longer than 2.2mm might hit or block something inside the camera or nothing at all. They sell by the piece:
M1.7x3 to M1.7x3.5 : Metric Screws!, We have the screws you need!
This company in Southern California has JCIS (I'm guessing the same as JIS) in 2.2mm pan head and 2.5mm flat head. They are a wholesaler only with a minimum order of $50. You could call a sales rep and sweet talk them into sending you some samples.
Machine Screws, M1.7 | The FCH Sourcing Network
You could always replace both screws so they match if that's what concerns you.
base, mx, mx base plate, pentax mx base, pentax service, plate, repair, screw, screws, service, warranty
Pentax Super A/Super Program camera base plate Theov39 Repairs and Warranty Service 5 04-26-2018 02:53 PM
Screws to mount silver plate back on a K-Mount Lens rjm007 Maintenance and Repair Articles 3 06-04-2017 09:27 AM
Lens Plate Screws (Arca-Swiss) stormtech Pentax Camera and Field Accessories 15 01-09-2014 12:02 PM
anyone know where i can get MX base plate screws? JDaughtry Pentax Film SLR Discussion 5 08-08-2011 08:34 AM
All times are GMT -7. The time now is 11:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
