07-01-2019, 08:23 AM   #1
Mode dial stucked at Manual
Hi all,
My K-01 experienced the mode stucked at 'M' no matter how I turn the knob. I've digged out similar posts, there are:
1) Due to contact dirty while switching between classic manual lens and modern lens
2) K-1 has an earlier production defects and has to be fixed by replacement.
I have tried cleaning the contact, re-install firmware hoping the software would restart by itself, both failed. Please help!
07-01-2019, 09:32 AM   #2
blackcloudbrew's Avatar
I have no direct experience with the K-01 but the same thing happened to my K-1 two years ago. The problem with my camera was mechanical, something actually broke and exactly as it is for you, my K-1 would only operate in manual mode. If it's the same thing for you and your K-01, this has to be sent to the repair shop for a fix. Sorry.
07-01-2019, 06:34 PM   #3
Thanks for the reply, I will try to dismantle and see whether it is a simple fix..
07-01-2019, 10:09 PM - 3 Likes   #4
PEG Moderator
Kerrowdown's Avatar
Location: Hielands o' Scootlund....... "Hold Infinity in the palm of your hand"..............William Blake
QuoteOriginally posted by raydream Quote
I guess it could have been worse... it could have been stuck in Auto.
07-02-2019, 10:27 AM - 2 Likes   #5
Reached the final step.. any suggestions what maybe wrong?
---------- Post added 07-03-19 at 02:04 AM ----------
OMG I've done it, found the mechanical fault, will post the instructions how to fix it soon
CLT-L29  Photo
07-02-2019, 04:00 PM   #6
35mmfilmfan's Avatar
Well done - I'd not have the courage or confidence to even attempt it.
07-02-2019, 04:10 PM   #7
Not a Number's Avatar
You didn't happen to take the front cover off? I'm curious to see what the design on the aperture control block looks like.
07-02-2019, 08:15 PM   #8
Here's how its done and the probable manufacturing defect!
witonosfreestyle.wordpress.com/2019/07/03/repairing-the-notorious-pentax-dslr-mode-dial-stuck/
07-03-2019, 02:51 AM - 1 Like   #9
As I recall the mode dial has a propensity to come off on the K-01, no doubt the problem is related.
As a side note the manual focus SMC Pentax-A 50mm f/1.7 lens often suffers from a problem in the aperture ring because of a similar failure on the tabs holding the leaf springs.
Thanks for sharing.
contact, lens, mode, pentax service, post, repair, service, warranty
Vivitar 28 mm 1:2.8 Auto VMC Manual stucked Aperture FabioPirovano Pentax SLR Lens Discussion 1 06-13-2019 10:08 AM
K-30: Lost Manual Mode on E-Dial knightzerox Pentax K-30 & K-50 7 12-06-2013 11:31 PM
slow to respond/ eratic e-dial adjustment in manual mode billsantos01 Pentax DSLR Discussion 2 09-05-2013 08:49 AM
Help, adapters stucked M.Zein Pentax Q 5 05-17-2013 10:49 AM
samyang 85mm stucked with LV random pentax user Pentax K-5 2 06-24-2011 09:53 AM
All times are GMT -7. The time now is 08:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
