08-20-2019, 04:52 PM - 1 Like   #16
ramseybuckeye's Avatar
Good Luck Ron, that looks like a nice lens otherwise. A lot of these ideas may work, but the lens vise looks best to me. If you can pull it off you may be able to get some real deals.
Tool makers or experienced machinists may have some other good ways to do something like that, but they usually don't work with something as fragile as a lens. A friend of mine who hand builds guns did a real nice mod on a quick release clamp for me.
08-20-2019, 06:47 PM   #17
$23 + shipping and NO guarantees!
FWIW...no shop will guarantee a filter thread straightening job.
Kill-Joy !
At least I will be learning something new.
---------- Post added 08-20-19 at 18:52 ----------
QuoteOriginally posted by ramseybuckeye Quote
I build Guns too ! And have access to a machine shop to Boot ! The Rokkor IS a really nice lens.....Going to try and bring her back to life......only cost me $5 for a whole camera bag of 6 lenses and a couple nice Minolta Bodies at an Auction , so Im not out much.
08-20-2019, 07:13 PM - 1 Like   #18
I also have the lens vise, and it's a joy to use. Just make sure the threads on the vise are properly aligned with the filter threads before you put pressure on it.
08-20-2019, 10:02 PM - 1 Like   #19
As suggested above. Use wood and a small hammer. But use soft pine dowel. something soft (eg rubber mat) under the lens body when you hit the dowel. The soft wood won't damage the thread. I have done this successfully as recommended elsewhere (can't remember which site). Dented lens was a Adaptall 300mm F2.8 shipped from NY and damaged in transport. Repair was successful and 112mm filter could be used.
08-20-2019, 10:53 PM - 2 Likes   #20
dms
After working on it, first try a filter ring w/o glass. Even if you force it one (and leave it on) you likely can use it to later add a filter or hood.
08-21-2019, 11:54 AM - 3 Likes   #21
QuoteOriginally posted by torashi Quote
I went an alternative route and used a Milling machine......Mounted the Mill Head in a Vise and used the 3 Chucks to carefully push it out. Got it 97% or better and a filter now goes on with some moderate tightness. A hood goes on easily. Shall I call it cured ?
Will post pics later , but it looks very acceptable and is almost unnoticeable.
Im still looking forward to my Lens Vise as I just won another Auction last night on a dented lens...It went for CHEAP !......lol
08-21-2019, 12:49 PM - 1 Like   #22
MossyRocks's Avatar
QuoteOriginally posted by Ronald Oakes Quote
nice
I would
08-21-2019, 03:34 PM - 1 Like   #23
Awesome, 3 points are better than 2. Cured!
08-22-2019, 06:46 AM   #24
That's what I was thinking. It wasn't perfect and I went slowly.
I will post an image of the milling machine head when I get back from the Shop this morning. Many may not have a clue what it even looks like.
Here is the finished Lens. Just a tiny bump left that isn't at all noticeable.
DMC-G3  Photo
DMC-G3  Photo
DMC-G3  Photo
DMC-G3  Photo
08-22-2019, 07:14 AM - 1 Like   #25
Seeker of Knowledge
aslyfox's Avatar
glad you had the equipment and expertise to use it
08-22-2019, 09:47 AM   #26
QuoteOriginally posted by aslyfox Quote
I don't have the expertise…...but a bunch of the Old Retired Guys in the Metal/Machine shop have about 1000 Years combined experience !
08-24-2019, 05:03 AM   #27
Camera Repairing Shops can fix that as well.
08-24-2019, 12:30 PM - 2 Likes   #28
ChrisPlatt's Avatar
My method using disposable, free tools mostly
QuoteOriginally posted by marcusBMG Quote
Lay the dented part of the lens rim on "blue tack" or plasticene, press it in.
Make a small hardwood tamp shaped correctly to the circumference profile.
Use a small hammer and the tamp, gently tap the dent out.
Paint stores here give away thin flat wooden paint stirrers for free with purchase.
I split one to an appropriate width and trim the end to match the radius.
The length gives good leverage and a safe working distance
The soft wood will not further damage the filter threads.
An "anvil" made of scrap soft building lumber (e.g 2x3) works well as a base.
Notching it to match the curve of the lens barrel will prevent slippage.
A few small blows with a small hammer are all that are necessary.
Once it is appears to be straightened check by screwing on a filter.
Repeat as necessary. Once filter goes on and off easily STOP.
If paint is badly chipped I use a black paint marker to touch it up.
A black Sharpie is often adequate for a small repair.
Your good results will make a little bit of extra prep time worthwhile...
Chris
front, front rings, guns, lens, lenses, pentax service, repair, rings on lenses, service, shop, warranty
Straighten those fishy pictures - Aperture hiepelines Digital Processing, Software, and Printing 2 01-01-2015 01:27 PM
How to straighten a bent metal Asahi Pentax lens cap? kcobain1992 Pentax SLR Lens Discussion 3 10-02-2011 01:44 AM
Nature Straighten that Back Soldier daacon Post Your Photos! 18 08-19-2011 04:58 AM
do you always straighten your photos in PP? aleonx3 Digital Processing, Software, and Printing 12 03-19-2010 04:55 PM
For Sale - Sold: Working 50mm f/2.0 Pentax-A SMC lenses with dented filter rings - 3 available wallyb Sold Items 4 05-09-2009 01:54 PM
All times are GMT -7. The time now is 09:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
