Originally posted by JimboWalker I spoke too soon. The shutter speeds are a bit erratic when matched with what is indicated in the viewfinder. The slower speeds seem off.
If you’re handy with electronics of the simple kind in the ESII and you can locate a circuit diagram, you could try using a multi-meter to check the continuity of the circuits. An intermittent fault such as you describe sounds like a dry solder joint or possibly a failing component. There were some repair manuals around on the Internet, as I recall, and I’m fairly certain there was an ESII one (I have an ESII, myself).
