If you want to risk firmware hacking the instructions for setting up the files on your SD card are here:
Resurrecting Pentax firmware hacking - Page 42 - PentaxForums.com
- Create the files on the card as describe in the above post
- Put the card in slot 1, leave the card door open
- Hold in Menu when you power on
- When the menu comes up the first item in the list is Enable Debug. Set it to Yes and hit OK.
- Then turn off the camera and close the card door
- Turn camera back on and the debug menu will show up. Just hit ok and your camera will now be usable.
- Press menu and scroll over to the right. Just after the wrench menu tabs there is a hidden tab called TEST MODE.
- In TEST MODE menu choose AF TEST
- For focus tuning here 10um=1 from the normal AF Fine Adjustment menu. Anything you set here will be additive to your other AF Fine Adjustments.
- When you are done turn off and back on your camera so the Debug Menu pops up and disable Debug Mode.
