10-03-2019, 07:41 AM   #16
Jonathan Mac's Avatar
Unfortunately, Pentax is like Ryanair - if it all goes fine then you're OK but if there's any problem then you're on your own.
Pentax should have issued a recall or service note that all the affected models should have the faulty component replaced for free, regardless of warranty period.
10-03-2019, 07:47 AM   #17
QuoteOriginally posted by Kozlok Quote
My K-30 is still going strong after many years. My daughter uses it now, and still works as good as new. Probably < 10,000 actuations on it though.
Sorry if it was mentioned before, but did you file the original solenoid plunger or replace that assembly with a white version?
10-03-2019, 08:56 AM   #18
Not a Number's Avatar
I helped out my brother-in-law by setting up a repair at Pentax Camera Repair - Aperture Control Repair . They guarantee their repair forever, you have to send the camera back and forth. Being in Canada, that's more complicated for us, sadly.
That's good to know. There was one forum member how had their camera repaired by PC35 and failed again after more than a year. I'll see if I can find the post and inform the member of the lifetime warranty.
QuoteOriginally posted by Jonathan Mac Quote
Ricoh seems to have left this problem up to the regional offices. In the US each failure is handled on a case by case basis with an inspection of the camera before a decision if the repair will be covered - to date with all cases reported on PF Ricoh covered the repair. In Australia Ricoh acknowledges the problem and covers the repair. UK and EU seems unwilling to cover the repair. The rest of the regions Ricoh's response is unknown as there have been no reports.
Take the matter up with your regional Ricoh office. These forums are not a direct conduit to Ricoh.
10-03-2019, 01:19 PM   #19
Dewman's Avatar
So PC35 is offering a lifetime warranty now (web page says one year)? And you've had no repeat failures on his fixes, correct?
Thanks, this is all valuable information.
I was told over the phone that the fix was a lifetime guarantee. I noticed in his web page that it says "One Year." So..... it looks like one year would be correct. Sorry if I mislead anyone. And no, I have had NO repeat failures. I might add, he's a very easy man to deal with, as is his wife. Nice people and the turnaround time has been less than three weeks for all three cameras. I have no dog in this fight other than to hopefully pass on some valuable information to those of us who dearly love our K-30's and K-50's and are willing to spend a hundred bucks to have it repaired. I do not personally know the guy who owns the repair company. I've only dealt with him over the phone and via email.
10-03-2019, 05:24 PM   #20
amstel78's Avatar
Maybe lifetime meant the lifetime of the solenoid... which is probably one year. Lol..
10-03-2019, 09:30 PM   #21
Kozlok's Avatar
QuoteOriginally posted by Vmax911 Quote
I think you quoted the wrong person. My K-30 has the original, unmodified aperture block.
10-04-2019, 06:48 AM   #22
My mistake, but congrats on have the original aperture block last 10K+. That's great!
10-04-2019, 07:04 AM - 1 Like   #23
Someone said it earlier in the discussion, but it probably also helps to keep using the cameras regularly. That being said, the whole aperture block failure simply should not have happened in the first place and it definitely should not have been allowed to continue in more recent bodies.
10-04-2019, 07:47 AM   #24
I used to have 2 K-30's, one suffered, one didn't. Sold the other and got myself a K-5iis.
10-04-2019, 05:25 PM - 1 Like   #25
Dewman's Avatar
Exactly! It would have earned Ricoh a lot more faithful followers than the position they took. Be that as it may, I'm glad I got my Lipstick Red K-50 back and it's now ready for several thousand more images. Matter of fact, it arrived back today.... a two week turnaround time.
09-20-2020, 02:19 AM   #26
One (of several) was member tonyzoc. His K-S2 failed just shortly after this 1 yr. warranty and he wisely chose to apply the DIY repair:
Solenoid problem return plus sound - Page 2 - PentaxForums.com
One can see very well how PC35 modifies the plunger of the solenoid and if one studies the information I tried to summarize here:
Why you shouldn't file/sand the plunger of the green Chinasolenoid but replace it - PentaxForums.com
I am not saying that the filing/sanding method will not work, it does work but with a risk.
The warranty still is 1 year but maybe PC35 just grants more but not officially.
Tonyzoc used a very hefty soldering method (butan gas soldering), so it went wrong.
Too bad because I actually gave precise instructions about how to do it:
Manual: Solenoid replacement: Pentax K-S2 (and K-70) - PentaxForums.com
But... He had the same problem with his K70 and was able this time to do it right:
Solenoid in Pentax K-70 - Page 4 - PentaxForums.com
09-22-2020, 06:51 AM   #27
retired sw engineer
reh321's Avatar
QuoteOriginally posted by HoutHans Quote
Pentax did change their design in later cameras,..... but the problem seems to have continued.
Since the problem seems to be based on calendar time - rather than use - this is a difficult thing to track down.
I think they should just drop the solenoid and use the stepper-motor-based solution that K-7/5/3/1 use.
09-22-2020, 11:49 PM   #28
QuoteOriginally posted by reh321 Quote
There is no need to give up on the principal of the solenoid.
All.... really all that needs to be done is to get a Japan-Solenoid, send it in to the manufacturer Shinmei but with a sledge-hammer and ask the manufacturer to find a magnet which holds the plunger with exactly the same holding force as does the Japan solenoid. That would solve it.
Just this weekend I repaired a K-70 of very recent manufacture....
It still had warranty and was repaired on warranty but failed again.
It was a good chance to fish for chips (it was quite a resisting chip, seems to be a stealth chip]
Anyway, the solenoid was even better than the previous one. Almost correct holding force!
Failures of the solenoid in the K70 are very rare, even Post-December-2015 K50's, K-S1's and K-S2's have way way less failures.
As I had many for repair, I never came across any which went wrong after that date.
09-23-2020, 04:00 AM   #29
retired sw engineer
reh321's Avatar
QuoteOriginally posted by photogem Quote
There is nothing wrong with the principle of the solenoid - but they seem to have never gotten it quite right since production moved;
solenoids just have not "aged" well - for some reason.
Pentax just has not been able to deal with the "aging" problem ..... and they certainly have tried.
I am very happy with the stepper-motor controlled aperture of my KP.
09-23-2020, 04:12 AM   #30
In Europe failures of the K70 are very few. The K70 is the most successful Pentax midrange body, failures are not at all higher than those of other brands or with the KP.
So it is totally wrong to say "Pentax has not been able to deal with the aging problem, they have been able"
Not only did they try but they succeed.
aperture, k-50, pentax service, repair, repairs, service, third, third k-50 aperture, warranty
My K-50 aperture or shutter problem or fix. jonnie_webb Pentax K-30 & K-50 10 07-10-2018 09:23 PM
Advice needed to fix a third party K-mount lens Pentaxis Pentax SLR Lens Discussion 4 12-04-2017 08:21 AM
DIY fix for k-30 / k-50 aperture block problem without any disassembly frozenshiver Repairs and Warranty Service 2 11-21-2017 12:08 PM
DA* 50-135-- to fix or not to fix, that is the question... geek-girl Repairs and Warranty Service 9 10-03-2017 03:07 PM
To Fix or Not to fix... That is the question Blacknight659 Troubleshooting and Beginner Help 3 09-08-2015 12:47 PM
All times are GMT -7. The time now is 01:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
