Originally posted by stevebrot I am tempted to message ChristianRock to find out what finally happened with the camera and whether they were able to resolve the mirror control issue.
When I received the camera, I could use it in the A position and live view, and it would stop down the lenses (but the mirror would slap 2-3 times in the process). It would not stop down lenses with aperture rings, however. I could also select the aperture for video.
The mirror just stays in random positions so the viewfinder never works. The mirror assembly must be somewhat broken.
Then I opened it up just to look at it, to see if there was any soldering that I could redo, or any lose wire, etc. After looking at it and verifying that everything looked correctly in place and the soldering looked very solid, I put it back together.
But now it won't even stop down lenses at all - aperture ring or A position.
I keep thinking I might get it fixed but at this point it's probably going to need everything inside, they'll probably change the board and mirror assembly and God knows what else, probably the whole thing, and probably cost at least the 300 dollars that I think it's worth. So I might just give it away for parts... it's got the white solenoid in it so it's probably going to be useful for somebody.
