10-11-2019, 12:49 PM   #1
noblenub's Avatar
FA 50mm 1.4 Sticky Focus Ring
I've got an older FA 50mm 1.4 that is starting to develop a 'sticky' focus ring. Every once and awhile the focus will lock up, and the focus motor can't drive the ring. Seems to happen near the end of the throw (fully CCW). I'll fix it by putting the camera into manual focus and rotating the ring myself past the spot, then putting the camera back to auto.
For sure it's an older lens and I could probably find an inexpensive replacement, but I thought I throw it out here to see if anyone has some thoughts on a quick-ish fix. Are they any suggestions of treatment without pulling the thing apart to clean it? Any success with contact cleaner (or similar solutions) that I can work into the lens from the outside? Any help would be appreciated. Thanks!
10-14-2019, 08:05 PM   #2
Gerbermiester's Avatar
I'm not familiar with this problem in particular. But, I've had my FA 50mm 1.4 serviced in Vancouver Canada for $60 when it got oil on the blades. That's about a third of the cost of replacement on the second hand market.
10-15-2019, 03:15 AM   #3
Not a Number's Avatar
The lens either needs cleaning and lubrication or one or more gears in the AF drive train is worn or broken. There probably isn't an easy fix other than opening up the lens to see what the problem is. Spraying a cleaner/lubricant will end up in places where it shouldn't be and cause more problems.
You would have to send the lens to someone for a repair estimate and decide whether it is more economical to replace or repair. The repair shop may even tell you it is beyond economical repair.
10-15-2019, 08:03 PM   #4
noblenub's Avatar
QuoteOriginally posted by Gerbermiester Quote
Do you have the name of the shop that repaired your lens? I'm just an hour away from Vancouver so it might be worth it to give them a shout. Otherwise I'll probably just save my pennies for a 55 1.4...
Thanks for the replies. I figured I was outta luck when it came to a quick fix, but it was worth a shot.
10-16-2019, 05:43 PM   #5
QuoteOriginally posted by noblenub Quote
That would be VanCam on West 8th. You can call them for a quote if I recall
10-16-2019, 09:09 PM   #6
noblenub's Avatar
Awesome thanks. I'll give them a shout.
50mm, camera, fa, fa 50mm, focus, lens, pentax service, repair, service, throw, warranty
K-3 and FA lenses - aperture ring setting / focus ring zzeitg Pentax K-3 10 11-05-2014 08:10 PM
Me super sticky shutter, stay's (a bit) sticky crabe919 Pentax Film SLR Discussion 13 07-10-2013 10:58 PM
sticky focus ring on SMC Pentax-DA 35mm F2.4 AL wedge Pentax SLR Lens Discussion 2 01-05-2012 01:22 PM
Sticky zoom ring on 16-50mm jamescp Pentax SLR Lens Discussion 2 05-20-2010 02:08 AM
How to fix a sticky aperatue ring on the A 50mm F1.7 Bob Tuttle Troubleshooting and Beginner Help 12 12-19-2009 08:21 PM
All times are GMT -7. The time now is 07:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
