Originally posted by bikehead90 I tried to use my aforementioned lens after a long time in my bag. It worked prior to being placed in my bag, but now doesn't work at all. I assumed it's the dreaded SDM motor, so I tried to convert the lens, but it would appear that PKtether doesn't seem to exist anymore. Does anyone have a solution?
Before you take it apart,
- make sure you have a full battery
- try to focus on something that has high contrast that is almost in focus
- use the back button
- make a small adjustment with quick shift bringing it in and out of focus
- keep trying to gain focus with the AF
- listen for a slight noise coming from the lens, if you here something keep trying for a bit.
- the smaller the focus adjustment the better until it starts to move then it should get easier
Be patient, it might come loose
