01-16-2020, 09:50 PM   #1
Help, canít work out how to fit part on K1000
Hola! Iím currently travelling Colombia where I picked up a second hand Pentax K1000 at a market. Iíve cleaned, checked over the camera and believe itís working (if anyone has any suggestions of what to check) but the fork that holds the film in place has come out and wonít go back in.
I have all parts and believe this is the only issue. If anyone has any advice Iíd really appreciate it, I was hoping to try my hand at photography whilst Iím travelling.
Thank you
01-16-2020, 11:20 PM   #2
Not a Number's Avatar
I don't know what you mean by fork? The spindle/shaft on the rewind or the spring on the pressure plate? The pressure plate should not be difficult to figure out. The rewind spindle more complicated.
Service manuals are available online. Try Pentax-manuals.com.
Pictures would help to see what you are talking about.
01-17-2020, 06:30 AM   #3
ismaelg's Avatar
Hello,
You need to insert it from the bottom of course, but you need something like a dental pick to push a little spring out of the way for it to slide up. This spring will hold it and prevent it from falling. It will look like a little wire when looked from the top.
Hope this helps!
Thanks,
Ismael
01-17-2020, 05:09 PM   #4
Looks like Page 48 of this PDF shows the item (04010) you are asking about, if I understand the question correctly.
Look at 04014, which appears to be the spring wire that Ismaelg mentions.
http://pentax-manuals.com/manuals/service/spotmatic_sm.pdf
hand, k1000, pentax service, repair, service, warranty
August, 2018 Winner: work...work...work... pakinjapan Winners' Showcase 56 09-14-2018 01:40 PM
Help! Need help identifying part that fell out of K50 during disassembly peterson390 Pentax K-30 & K-50 6 08-12-2017 10:18 AM
Can someone help confirm if Metz 58 can work as a HSS master with Cactus stuff Grognard Flashes, Lighting, and Studio 5 02-28-2017 06:53 AM
People Work Work Work mel Post Your Photos! 3 07-28-2014 11:49 AM
HELP! Do these lenses fit K1000 & K10D? allie181 Pentax SLR Lens Discussion 23 02-17-2007 07:13 AM
All times are GMT -7. The time now is 05:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
