Show Printable Version 13 Likes Search this Thread
01-20-2020, 03:33 PM - 1 Like   #1
MarkJerling's Avatar
K-1II hotshoe mount broken
Bit of bad news. I'm generally very careful with my equipment so I'm absolutely flabbergasted as to how this happened. We were away for a few days which involved both train and airplane travel.
The camera when not in my hands travel inside a very well padded large camera bag with the camera in it's own compartment separated from any lenses. I did not have a flash with me for the trip and noticed the damage yesterday when changing lenses. It must have received a knock somewhere along the way but as to how this could happen through a well padded camera bag I'm not sure. I've not knocked the camera against anything.
I have contacted the New Zealand Pentax service agent this morning and am waiting to hear from him with regards to costs to get this sorted. The camera will likely need to go to Japan to have this fixed.
From an online search it seems the top plastic is very thin. If you have a K-1 I'd advise taking extreme care with the top of the camera! I'll post more when I know more.
SM-J610G  Photo
SM-J610G  Photo
SM-J610G  Photo
01-20-2020, 03:44 PM   #2
Aaron28's Avatar
that stinks!
have you tried using flash?
01-20-2020, 03:57 PM   #3
QuoteOriginally posted by Aaron28 Quote
that stinks!
It sure does. No, I can't mount a flash as the plastic hotshoe cover cannot be removed as the pushed-in mount prevents the cover from being slid out. Even if I could get it out, I would not try mount a flash as I would not want to risk a short circuit or any additional damage.
01-20-2020, 04:03 PM   #4
Fries's Avatar
That is really bad luck Mark. Airplanes and the overhead compartments can be a bit tricky. Once a hinge in the overhead compartment crunched a part of my K-5 and the top LCD cover came of. Since then I alway's stay away from those hinges with my camera bag.
01-20-2020, 04:09 PM   #5
luftfluss's Avatar
Wow, that is terrible. Is there any sign of impact on the camera bag?
This morning I read 2 recent laments of the tripod mount on the new Olympus camera breaking; when we are shelling out serious cash for these nice cameras, we should feel secure knowing they can take a few knocks.
01-20-2020, 04:55 PM - 2 Likes   #6
Not a Number's Avatar
Definitely a weak spot on the K-1 series. At least a couple other forum members report damage to the prism housing - from drops or falls as I recall. The top cover in this area needs to be beefed up. The designers must have made some compromises to accommodate the GPS antenna and circuitry.
01-20-2020, 05:31 PM   #7
It did happen to my K-5ii once and flash was mounted and was hit by someone walking by when the flash was mounted... The metal housing of the show popped off with the flash that was a bit loose (very minor play if at all) to begin with. Had to send it for repair.
In your case it seems the camera went into a lot of stress on top of the hot shoe (got squished against an edge of a seat or the passenger bar in trains or the latches of an over head bin without you noticing it).
It is not easy to break it the way it is seen in the picture. It probably succumbed to a lot of pressure..
01-20-2020, 06:07 PM   #8
QuoteOriginally posted by Fries Quote
I don't think it happened there, but who knows. I certainly did not see any hinge. I think damage on the train may have been the likely cause. Or, shuttle service from train to airport. It's a mystery.
01-20-2020, 06:10 PM   #9
QuoteOriginally posted by luftfluss Quote
No, the camera bag is perfect. Knowing how many knocks my K-5 and older Pentax cameras have had, and how I've been babying the K-1II, this has come as a bit of a worrying surprise. I've been more "careful" with this camera than any one of my previous cameras!
01-20-2020, 06:18 PM   #10
Yes, there have been some reports. I've wracked my brain as to where it could have happened. Looking back, I think I can rule out the airplane. Not the train ride. That was bumpy as train rides can be but the camera or camera bag was never out of my sight. ANd no bags were stacked on top of the camera bag at any time. I'm real confused at how this could have happened. You have no idea how careful I've been with this camera!
01-20-2020, 06:26 PM   #11
QuoteOriginally posted by shardulm Quote
The camera was not in any situation where it could have been subjected to a "lot of stress" At all times, I handle the bag with care and the camera with more care. It's also never out of my sight when I travel. Having said that, I could have bumped the well padded bag against something while it was on my back and not noticed. (It is a back-pack style bag.)
There's no impact mark on either the bag or the camera and the camera is functioning perfectly. (Other than the hotshoe issue) Looking at it closely, I can confirm that the plastic is very thin - less than a millimeter.
01-20-2020, 06:29 PM   #12
Leumas's Avatar
Any point where it was checked baggage?.....that's the only thing I could think of
01-20-2020, 06:49 PM   #13
QuoteOriginally posted by Leumas Quote
No, I'd never do checked baggage for a camera.
01-20-2020, 08:06 PM   #14
Otis Memorial Pentaxian
That is really a shame to see that damage. With any luck it is only the hotshoe base and the prism cover that is broken.
A few years ago I had my camera bag in the overhead during a hard landing on a short runway. The pilot was very hard on the brakes and due to the flight not being particularly full, we could hear the bags in the under-filled overhead sliding forward and crashing into the bulkhead. I figure my camera bag hit at about 40 mph. Fortunately, the K-3 and more sensitive lenses were in a smaller bag between my feet. No more overheads for the gear unless in a hard-side or in very thick neoprene pouches.
01-21-2020, 02:46 AM   #15
Is why I like a full metal body, none of this gps and wifi rubbish, full metal housing.
bag, camera, k-1ii hotshoe, lenses, pentax service, repair, service, travel, warranty
FA 50mm focusing is broken. Fix it or sell as broken? Tranzistors Repairs and Warranty Service 5 01-30-2018 11:53 PM
Broken Plastic Hotshoe on Flash Trigger. Suggestions? reivax Flashes, Lighting, and Studio 7 01-31-2012 09:46 PM
Wanted - Acquired: Wein Safe Sync hotshoe to hotshoe adapter gabriel_bc Sold Items 1 06-13-2011 05:01 PM
Lens is broken: broken mount nemo9439 Pentax SLR Lens Discussion 4 08-27-2010 09:52 AM
All times are GMT -7. The time now is 09:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
