01-26-2020, 05:05 AM   #1
Pentax MX advance lever no 20 degree position
I was wondering which part keeps the advance lever in the 20 degree position needed to engage/disengage the exposure meter? The advance lever works great, it just does not stay in the 20 degree position, but rather goes all the way back when the shutter is fired. The only real problem I have with this is that it drains my batteries so there's no point in putting them in the camera, and I would really like to have the exposure reading visible in the viewfinder.
I'm thinking of fixing it myself if it's not too difficult. I have an ME available as donor body if needed. Do I fix this from the top or the bottom of the camera?
01-26-2020, 11:57 AM   #2
Otis Memorial Pentaxian
I am not quite following you here. I don't have an MX at hand, but my KX has essentially the same operation. On the KX (my camera), the expected behavior is:
  • Meter is enabled with the wind lever in the "ready" position of 20 and disabled with the lever stowed against the body. The meter switches on with half-press of the shutter button and stays on until the wind lever is stowed against the body or the shutter lock is engaged.
  • Shutter release works both with the wind lever stowed against the body and in the 20 position
  • After pressing the shutter release, the wind lever stays where it was before the button was pressed
  • After using the wind lever for film advance, the lever returns to the 20 position unless moved against the body by user action
What aspect of the above is not working properly?
01-26-2020, 12:32 PM   #3
There is a free pdf copy of the MX Service manual on the Pentax Manuals Web site:
Pentax Manuals | Service Manuals
It might provide some clues.
01-26-2020, 04:15 PM   #4
[*]After using the wind lever for film advance, the lever returns to the 20 position unless moved against the body by user action[/LIST]What aspect of the above is not working properly?
This one. The lever on my MX does not return to the 20 position after advancing the film. It moves directly to the position against the body, it skips the 20 position.
01-26-2020, 04:20 PM   #5
QuoteOriginally posted by deepbluish Quote
OK...
Are you able to turn off the meter using the shutter lock?
01-26-2020, 04:28 PM   #6
I can't check because my batteries are empty, and I'm out of spares right now.
01-27-2020, 07:10 AM   #7
I've just checked with new batteries. The shutter lock does turn off the light meter.
advance, camera, degree, exposure, lever, mx advance lever, pentax mx advance, pentax service, position, repair, service, warranty
Pentax MX advance lever is stuck Lalalalala_ Pentax Film SLR Discussion 5 01-22-2021 02:38 AM
Plastic piece for advance lever on an MX John Brown Pentax Film SLR Discussion 6 01-23-2019 08:41 AM
MX with jammed shutter Release & advance lever Frosty66 Pentax Film SLR Discussion 5 05-24-2017 01:56 AM
All times are GMT -7. The time now is 07:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
