Originally posted by AfterPentax
It is not a case of missing an insulating disk, because there is no insulating disk. It is just a blind spot for the inside contacts and bayonet as well. So that contactpoint is not necessary for transporting electrical information back and forth to the camera. That is why it is closed.
Interesting interpretation. That spot is normally occupied by the M1 contact which in tandem with the M2 contact codes for minimum aperture. Lenses on my shelf have flat metal, a conductive plug, an insulator, or a ball contact with insulating collar* at this location. I have none with a pit, though I have several with an insulating disk.
Addendum: I did a survey of Tamron 70-200/2.8 at auction and they appear to have a translucent plug at this location. Perhaps another owner could check in. (@northcoastgreg ?)
On non-AF bodies, the contacts are passive and code for aperture range and minimum aperture by simple continuity test. The table with the aperture encoding is at:
Features and Operation of the KA Mount | The K-Mount Page.
* This type can code either high or low depending on the wiring behind the mount.
