Originally posted by normhead You do understand that as soon as you say "some SDM lenses" you've made the error of assuming all SDM lenses are the same?
I don't understand it like this.
When I write that some SDM lenses can't be converted to screwdrive, and that I hate that limitation, I am quite clear about it.
I mean "some SDM only" lenses and that means no screwdrive mechanism.
Where is this error you speak about?
Originally posted by normhead And the in buying an electrically focusing lens like the 55, you have added another component that can fail, compared to screw drive?
What is "the in buying"?
All SDM lenses are AF lenses with an SDM motor, and yes, an SDM motor is driven by DC voltage.
Any SDM motor can fail, but all SDM lenses except one which have the screwdrive mechanism built in but not activated can be converted to screwdrive.
Makes them faster as well but louder.
Originally posted by normhead I recently took my 60-250 out briefly after realizing I hadn't used it for 6 months, and it worked much better than I remember it working. MY anecdotal contribution would be that it works better if you leave it in the cupboard for 6 months. Hence highlighting the problem with anecdotal evidence. It can go either way. The only thing lost is the truth about how likely the issue is too occur. Anecdotal evidence may be small part of the truth, but it's along way from the whole truth.
That is not my experience with my two DA55SDM's. One has to use them constantly, leaving this lens unused makes it worse, which is actually common and accepted knowledge in the Pentax community in Germany/Switzerland/Austria (Pentaxians Forum Germany)
