Originally posted by dlh what??? this is the first time I've heard of this problem - at least in this context. I've had one that stopped working, and sent it back to precision for fixing, but it hadn't been in storage. Is there more than one SDM motor problem? Can someone explain what, exactly, is going on with this, or supply links to threads with descriptions?
There’s only one problem with the old SDM drives, but a lot of confusion about what it actually was (the piezo drive motor used to jam, causing the AF to stop working). There are many threads about the problem and a couple of realistic threads about how to fix it, including reprogramming the drive to disable the SDM and rely on the in-body AF drive (which I did, eventually). The problem was mainly but not exclusively confined to the DA*16-50, although others such as the DA*50-135 also sometimes exhibited it. Early drive replacements sometimes didn’t fix the problem permanently, but later ones appear to have done. Lenses did not need to be “in storage” (Ie put away for weeks or months at a time) for the problem to appear – mine would exhibit it again after a period of a couple of hours of not shooting.
Hoya, then Ricoh, both refused to acknowledge that there was a design issue with the drive, but subsequent replacements seem to have been fitted with drive motors that don’t jam.
