09-02-2020, 05:23 AM   #1
K1000 repair to correct inoperative release.
Hello. I have started taking apart the body and have had to destroy a very tight left handed disc under the counter, so I am looking for that part. Also, the degree of disassembly is my next question. Any K1000 fans here? Thank you for any guidance in advance.
09-02-2020, 07:28 AM   #2
Not a Number's Avatar
You would have to look on some place like eBay either for the specific part or donor body. Service manuals are available from many sources such as pentax-manuals.com or searching the Web. There are also videos on youtube that may cover disassembly of the parts in question.
09-02-2020, 07:36 AM   #3
Also, note that part is the same as on the Spotmatic. I recently got a parts Spotmatic for $19 which annoyingly works perfectly ( how can I use a perfectly functioning camera for parts).
09-02-2020, 09:38 AM - 1 Like   #4
MikeMcE's Avatar
No release? Most common cause is a bump/impact causing the mirror tensioning lever to unlatch. It is easy to reset this with only the bottom cover screws removed. Pull it back to latch, then try release. The mirror rises, tripping the first shutter curtain release.
In this picture mirror is tensioned and latched
Hang up and DRIVE!
09-02-2020, 03:28 PM - 1 Like   #5
Thank you Mike for your help. Did not know about the Pentax site. Thank you for that for sure.
09-02-2020, 03:34 PM   #6
MikeMcE's Avatar
here you go
09-02-2020, 03:40 PM   #7
QuoteOriginally posted by MikeMcE Quote
here you go
I found that tip in the service manual I have. All was right on my latch.
---------- Post added 09-02-20 at 03:50 PM ----------
QuoteOriginally posted by pentaxus Quote
I did not know about the Spotmatic parts interchangability. Thank you. I did see a few of them on ebay.
---------- Post added 09-02-20 at 03:54 PM ----------
Sorry, N a N, I called you Mike. Good advice. Plese keep me in mind if you think of anything. Or send someone you know who has taken the K1000 apart, Ok? Thanks.
09-02-2020, 04:17 PM - 1 Like   #8
MikeMcE's Avatar
QuoteOriginally posted by Analog Dave Quote
Ive repaired 1000s of H3V on up . The only weird one is the Spotmatic F, but mechanical yall the same basic thoughts.
Google NatCam Spotmatic repair guide. This is a pdf.
http://mattsclassiccameras.com/wp-content/uploads/2016/07/Pentax_spii.pdf
Hang up and DRIVE!
ebay, k1000, k1000 repair, pentax service, pm, post, repair, service, spotmatic, warranty
Wanted - Acquired: Inoperative Pentax P30 ConstIva Sold Items 0 06-21-2011 01:52 PM
Wanted - Acquired: Inoperative unrepairable Pentax SF-10 ConstIva Sold Items 5 02-03-2011 08:50 AM
New ACR Lens Correct vs K-5 in Camera Correct emblemex Pentax K-5 12 12-08-2010 12:20 PM
Have Any Of You Bought An "Inoperative" From KEH? vinzer Photographic Technique 6 11-23-2008 05:10 AM
All times are GMT -7. The time now is 08:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
