09-22-2020, 01:47 PM   #1
K-01 shutter stuck
Unfortunally my K-01 shutter mechanism starts stucking. It shows all symptoms of the solenoid issue.
The K-01 is same generation camera as the K-30, but seldom mentioned for the Chinese "green" solenoid issues because it seems to use a different mechanism.
Has anybody experienced this issue also at a K-01 and is it reparable?
09-22-2020, 02:35 PM   #2
maw
maw's Avatar
Hi Henrico,
Problem that affects many reflex cameras, however before raising the white flag, read this post of 'Photogem'.
Detection of aperture block failure on Pentax DLSRs with solenoid
Do not give up, Mario
09-23-2020, 04:12 AM   #3
After the K20D all Pentax semi-professional bodies had no more solenoid but a stepper-motor which hardly ever breaks! It seems the K-01 does not have the green solenoid but has a stepper-motor.
Is that really the case, and so, is that the part that has to be replaced?
disassembled pentax K-01 - Google Zoeken
09-28-2020, 12:03 PM   #4
Does K-01 has a green solenoid aperture control?
I think my last reply did not made my point; my K-01 shows symptoms os the solenoid aperture stuck, but it seems not to have one...
To fix it, should I replace the stepper motor ?
Has anyone ever disassembled a K-01 ?
10-06-2020, 12:06 AM   #5
The K-01 has the stepper-motor:
https://dc.watch.impress.co.jp/img/dcw/docs/519/765/032.jpg
which is from this side:
????????????????????????K-01?????? - ???? Watch Watch
and partly disassembled:
Pentax K-01 LCD Repair/Disassembly - Album on Imgur
PENTAX K-01 DISASSEMBLY INSTRUCTIONS Pdf Download | ManualsLib
The stepper-motor you can get here:
Pentax 77240-0G200 Diaphragm Control Block K-5 K-7 | USCamera PartsUSCamera
I would first open the K-01 though and check if it is really the motor not working.
10-06-2020, 05:24 AM   #6
retired sw engineer
reh321's Avatar
QuoteOriginally posted by Henrico Quote
What symptoms are you talking about?
Have you watched aperture while you take a photo?
Have you tried camera with lens that allows you to set aperture using aperture ring?
10-06-2020, 01:49 PM   #7
Thnx photogem, very helpfull sites. Problem on my K-01 is that the mechanism that has to shut down the aperture seems to be lame. I can move it up and down with my finger without giving much resistance. Totally different with my K1. Putting on a lens on it (M-lens or XS-lens) results in an unfinished aperture cycle, the aperture pin of those lenses causes too much resistance and also the shutter is not fulfilling its cycle because of that. Shooting without a lens on it works fine, the pin has no work to do, the shutter works fine and snappy. So for sure it has to do with the electric aperture mechanism that feels lame. Something inside is broken or the stepper motor does not function anymore.
When I have the guts, and am in a relaxed mood, I will open my camera to inspect whats wrong with it. Or maybe I will bring it to a local repair shop with the gathered information here, very helpfull those disassembly instructions.. Thnx!
10-06-2020, 11:22 PM   #8
One thing you can do is to reset the camera.
It might be useless but it is worth a try which doesn't cost you anything.
How high is the shuttercount?
If very high, then think about a K-S1 as replacement. It might turn out cheaper, K-S1's can be found sometimes for little money when the aperture is stuck, which is the solenoid.
Then you check the tutorial I wrote about how to replace it, it is easy and hardy anything can go wrong.
I had the K-01 and liked it for its design but as my wife has 2 x the K-S1 and I use it occasionally I find it truly better.
I would not invest in a damaged K-01.
10-07-2020, 12:01 AM   #9
Shutter count is 15k, not that much...
I like the K-01 for the looks and because it's the only mirrorless camera with full K-support. I use it most with the small M-lenses (20, 28, 35, 50, 85, 100, 135 and 200 mm's). Those lenses are small and perform real good on the smaller APS-C format. My K-lenses found home on my K-1ii. The K-equivalents often perform better on full frame simply because there is more glass in it. The M-lenses have great looks on my white K-01, and a glued a "Hoodman Pro" on it to make manual focussing spot on with the 6x magnify function. So I like my K-01 a lot, I certainly will try to fix it.
10-07-2020, 12:47 AM   #10
Then: A damaged K7 or K5 has the same motor in it!
Very rare that the motor goes wrong.
It is not that difficult to disassemble and first find out if there is just something else stuck.
If you google "pentax K 01 shutterproblem" you might find more.
10-07-2020, 04:00 AM   #11
Thnx photogem, I better first assess what's wrong inside the camera...
issue, k-01, k-01 shutter, mechanism, pentax service, repair, service, shutter, solenoid, warranty
K-50: Shutter stuck closed mirror stuck in upper position after power failure aaron_r Pentax K-30 & K-50 13 07-05-2020 01:56 AM
K-x: focus permanetly stuck on MF (manual focus) & Shake Reduction stuck Off too marty-0750 Troubleshooting and Beginner Help 2 04-18-2019 01:10 PM
Shutter not opening, shutter button stuck and unresponsive ( Pentax ME) pentytaxy Troubleshooting and Beginner Help 4 04-16-2016 12:54 AM
KX stuck in autofocus, but switch is stuck in MF icywarm Troubleshooting and Beginner Help 4 08-07-2012 07:21 AM
Pentax KX Shutter starting to stuck at slow shutter speed. Spirit722 Pentax Film SLR Discussion 7 03-03-2011 09:49 PM
All times are GMT -7. The time now is 11:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
