Originally posted by nicolpa47 My K50 has started to show the first signs of the aperture solenoid fault and I am preparing to do a self repair. This thread has been useful in that it has confirmed a few thoughts I've had. I have followed this subject on previous threads and it seems to me that preparation, care, and soldering capability are the important factors.
Yes, soldering is very important.
Originally posted by nicolpa47 I have experience of soldering, sometimes with small and heat sensitive components. My interest in model railways means I have 12v soldering irons with alternative bits and controllers to alter the bit temperature. I also have available low melting point solders and thought to use the 145 degree version.
That is perfect of course. I never heard of 145 degree solder nor other degrees.
Originally posted by nicolpa47 I am waiting to receive a non-working camera purchase from which to harvest at least one solenoid. Some time ago I did strip a solenoid from an MZ50 but I think Photogem prefers to use solenoids from later dslr cameras which I hope to obtain. It is clear that space to solder will be limited, but I could practice on the non- working camera.
Good not to use the MZ50 solenoid. There are tiny differences but if you buy a K100D or any of those with 2 solenoids, you can insert it into the flash-circuit, there it will work. Also if opposite polarisation (as many SLR Pentax solenoids in Europe are) there changing wires is very easy. Not so for the aperture-solenoid.
So buying a working *ist-D Series (I still like the D and DS due to TTL) or a K100D/K200D is maybe even more sensible. They are not expensive.
Originally posted by nicolpa47 I won't be rushing to do the repair as the K50 is only a back up, but I would like to keep it working.
Thanks to all, but particularly Photogem, for the guidance on how to repair this fault.
You are welcome, and yes, don't rush, good preparation is half of the work!
Originally posted by dlh Is there no way to use a heat sink on the leads while soldering, as you would for a diode or transistor? (I'm not familiar with the part, so I have no idea how much room you've got to attach the heat sink.)
There is no need for heat-sink here at all, it would disturb! The wires have tiny contact area directly to the pins.
Also one hardly uses heat-sing on diodes or transistors. More for longer connections which could cause shortage if bare, such as capacitors or resistors and wires/cables which had been extended and the soldered parts need to be protected.
The wires to the solenoid must be flexible as they are:
