Originally posted by officiousbystander
They're honest, efficient and happy to tell you if the job isn't worth doing.
I've purchased dozens and dozens of lenses "for parts". Most I thought I might be able to successfully repair/clean. From my experience, I've found that you never know for sure going in to most lens repairs if you can clean / repair the lens or not.
For example, I've been fooled more than once by haze and fungus thinking that it would be an easy repair job. But once inside, I determined that none of my 6 or 8 solvents would effectively remove the haze or fungus residue. Also, it's easy to mis-diagnose a problem. On occasion before taking a lens apart, I iniitially thought the problem was fungus or haze and once inside found that it was really "separation" (a fatal and non-repairable problem).
But, we've all got to start somewhere. So, if you can afford to trash this lens you're having problems with, I encourage you to
watch a few YouTube videos on lens repair, buy a few rudiementary
lens repair tools, and have a go at it. Your success rate will go up in time, but even after doing it for over 10 years, I still end up trashing a lens every so often because I was unable to repair/clean it.
Good luck and have fun!
